Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 10-25-2014, 03:12 PM   #1
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
V6 oil pressure
I have the V6 engine in my Camaro. I would like to know what should be the low reading. When I had the Gm gauges it was around 30 lbs at idle. So far I have tried 3 oil gauges and all read about 20 lbs. Is this a normal reading?
Caddy
Caddyroger is offline   Reply With Quote
Old 10-25-2014, 03:17 PM   #2
Mouse6.2
Mouse6.2's Avatar
Drives: 2013 2SS/RS M6 NPP
What RPM are you getting 20psi? General rule is 10psi per thousand RPM. If in doubt hook up a mechanical oil pressure gauge and see what your PSI is.
Mouse6.2 is offline   Reply With Quote
Old 10-25-2014, 03:23 PM   #3
Caddyroger
Caddyroger's Avatar
Opps forgot to mention it is at idle.
Caddy
Old 10-25-2014, 03:35 PM   #4
Mouse6.2
Mouse6.2's Avatar
20psi at idle is plenty of pressure.
