10-24-2014, 09:40 PM | #1 |
Drives: 2013 AGM RS 1LE Join Date: Dec 2012
Can i reach 500HP with these mods??
1) Ported LS3 cylinder heads - Scorpion LS17 Rocker Arms
2)Camshaft 3)LT Headers (No Cats) 4)Cold Air Intake 5)Performance Clutch 6)Performance Tune |
10-24-2014, 09:49 PM | #2 |
Drives: 2011 SS (Sparrow Spearer???) Join Date: Aug 2013
fly wheel no problem, probably 5-15 rwhp from 500
Black magic woman, don't turn your back on me baby!
10-24-2014, 10:22 PM | #3 |
How much rwhp be from sl headers and a CAI GIVE ME ON A STOCK L99 2014 OH WITH MUFFLER DELETE? ?? |
10-24-2014, 10:25 PM | #4 | |
Drives: 2017 Summit White 2SS A8 Join Date: Oct 2013
lethal performance just did a 1le with night fury cam, roto fab cai, headers, and dyno tune and made 500rwhp without heads. so if you do heads and get a cam spec'd for your goal its possible.
Mod List: Stock (for now) |
10-24-2014, 11:32 PM | #5 | |
Drives: 2011camaro SS Join Date: Nov 2012
To answer your question yes it's possible. Not super easy but possible. |
10-25-2014, 12:46 AM | #6 | |
Drives: 2013 SS Join Date: May 2013
10-25-2014, 02:48 AM | #7 |
No
2013 VR Camaro 2SS/RS LS3
Small, but effective mod list: Roto-Fab Intake, TSP 2" Long tubes, TSP catless mids, MSD spark plug wires, stock catback, Elite Catch Can, APEX washer relocation and scoop, VMAX throttle body, Diablo InTune-Tuned by Matt@FSP, and a JacFab license plate bracket. |
10-25-2014, 08:18 AM | #8 |
old school chevy rodder
Yes and you can do it without the clutch, the porting of the heads and different rocker arms, Read my signature. The right aggressive cam is everything along with the right tune and a good free flowing exhaust. I did pick their best at TSP, got the best tuner around and have electric power steering and dual mode, and BTW my car is a friggin beast when I use my mild to wild switch especially radical sounding on take off like people move over............ and everyone at my work knows when I leave and they are far far away surrounded by concrete..... you will need to remap the fuel tables to avoid ever going lean, and ditch torque management, and well have the best tuner around who knows WTF he is doing in a computer program and have him with a ton of experience and a library of all his past tunes for like engines to base his experience on..mine just happened to have two electrical engineering degrees but really a tuner can be a mechanic if he knows computers well and dyno tuning etc...... And yes my tuner drove the car, if he did not I would be pissed.... here is my car down the list at Wongs called marks car...I made 491 rwhp before I swapped the throttle body and the pulley to a 25% udp so I should be right around 500 rwhp and I am on a honest more reliable Mustang dyno which is usually very conservative compared to dyojet dynos as they are different big time.
And yes I am still waiting for Vararam to make a good intake so I can get even more N/A h.p. and torque without doing our great flowing heads or worrying about trunions which were mainly just a problem on the first year of the ls7 or changing from the stock single roller timing chain and oil pump until down the road when I check the cams springs every twenty five thousand miles..I am at about five now.... https://www.facebook.com/pages/Wongs...g/115667950915 Good luck to you in your build, just because some say it cannot be done it may be they compromised on one of the most important factors....like the cam shaft, or the tune, and I went for least amount of money spent while being able to have a mech do the work and it was about five grand parts labor fluids etc...and I used driven racing oil br30 for break in twice ditching it after dyno tune then 500 milles down the road and now run ls30, and BTW most times I have seen nightfury cams dyno tuned on here with honest numbers they came out like 20 h.p. under my cam and no one posts the specs of the night fury cam on here... My cam is .639/.623 with a 112 lsa and a 235/239 duration and custom proprietary opening and closing ramps made by TSP and I dig it man. Sure bring on the haters now..... and consider the differences between the mustang and the dynojet....
10-25-2014, 10:04 AM | #9 |
Ok sounds good, I appreciate the feed back.. Also what brand would you recommend for valve train upgrade/replacement? Rockers, springs, rods etc etc..
10-25-2014, 04:07 PM | #10 |
Drives: GM Join Date: Sep 2010
Well I'm at 495 with mods below and that's with 13/4" headers on a dynojet
Roto- Fab Cai, SLP 1 3/4" headers, 3"X pipe, LM2 cat back, Comp Cam & AI Heads, SLP UP, RPM Tuned, GPI Intake, Vmax TB, ADM Air Scoop, 3.91 Gears, Gforce driveshaft, Braille 21#, Elite Catch Can, Pfadt Tie Rods, Diff Bushings and Trailing arms, Eibach spings & sways, BMR cradle bushings, Nt555r's.
11-08-2014, 08:33 PM | #11 |
id also add the fast intake manifold and Big Mouth TB..
11-08-2014, 09:54 PM | #12 |
I wouldn't IMO
11-08-2014, 11:13 PM | #13 |
Waste of money.
Get with Brian Tooley Racing on your valve train.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
11-09-2014, 11:21 AM | #14 | |
Hey tried to PM you. I'm in Seattle area and had some questions about Tom Wongs spot down in Vancouver
Cold Air Inductions CAI Stainless Power LT's with HFC's Flowmaster American Thunder Cat Back APEX Scoop and WW Relocation Kit VMAX Ported Throttle Body Custom Dyno Tune Pfadt 1.25" Lowering Springs ZL1 Rims on 275 front 315 Rear custome underlay vinyl wrap Anvil Spoiler heritage grill APR Front Splitter Custom Emblempros emblems ZL1 Side Skirts 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
