08-29-2014, 09:48 PM | #1 |
Drives: 2013 Camaro ZL1 Join Date: Oct 2012
FYI - Replaced brakes at 68k
Another FYI,
I replaced my brakes all around. I think the pads would have made it to 75k miles before metal hitting metal, I've replaced mine at 68 as recommended by dealer after inspection. I took pictures but they sucked. Looked like 2-3 mm of meat left. GM does not recommend resurfacing the rotors, so expect to replace the rotors and pads. Total cost: $1800. $1200+ front, $600+ back. I put Hawk HPS on. Solid pad.
08-29-2014, 09:53 PM | #2 |
Look at the mileage a lot of the ZL1 owners are putting on. It'll take decades to reach that many miles for most of them. Depending on usage, racing vs non, it'll be vastly different formost.
Todd in Vancouver
'14 ZL1 Camaro '67 Camaro SS Pro-tour in process How hard can it be... Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession |
08-30-2014, 05:08 PM | #3 |
Drives: MANual Join Date: Jul 2013
08-30-2014, 05:16 PM | #4 |
Drives: 2015 SS Sedan M6 Join Date: Dec 2009
09-01-2014, 09:43 PM | #5 | |
Drives: 2013 ZL1 Join Date: Oct 2011
http://www.amazon.com/ACDelco-177-11...ype=automotive http://www.amazon.com/ACDelco-177-10...rds=rear+rotor here is the front and rear. I just want to post this in so other people don't get taken for a the price ride.
shopping for 2017+1le or zl1
2009 CTS-V -sold 2015 Hellcat-sold 2013 ZL1 -sold 2007 Z06- sold 2014 Chrysler 300 2011 Duramax 8" lift, deleted tuned |
09-01-2014, 10:35 PM | #6 | |
Going for Plaid
Drives: 2011 C6 Join Date: Jan 2010
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance. 2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14) |
09-02-2014, 12:37 AM | #7 | |
Sure its a little more expensive, but what I get with all that is a warranty. You'll find with most online retailers, the warranty goes out the door once you've installed it and you wont find anybody who will warranty the labor if the part fails. I see a lot of people make this mistake and end up spending even more money by doubling up on the labor for replacing a bad part as well as buying a new part cause the online store blames the installer. I'd imagine something coming from Amazon LLC is probably a safer bet then most shifty online retailers though. Also as a heads up, if you don't get a dealer to do it, you can find yourself on your own for the rest of the warrantied brake parts such as calipers, etc. All it takes is forgetting something simple like greasing the caliper. And I'm not sure if the AC-Delco part is classed as a aftermarket part or not. AC-Delco doesn't necessarily mean its the actual GM OEM part. So be careful when you go cheap. Sometimes it's better to pay more up front to save you suffering later.
09-02-2014, 02:45 AM | #8 |
1st Civ. Div.
Drives: Camaroless for now...RIP "Big SexZ" Join Date: Dec 2007
Why did you need to replace your rotors? Where they warped? Where they below minimum thickness?
Swift....Silent....Deadly
09-02-2014, 03:18 AM | #9 |
ROAD COURSE JUNKIE
Wow $1800
Glad I do my own work
09-02-2014, 07:48 AM | #10 |
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
Post #2 has a point. Honestly speaking, I don't think mine will ever reach that mileage during my ownership. On the other hand, that mileage range is excellent in terms of the ZL's brake durability.
Resurfacing....hah I couldn't tell you the last time I've had rotors resurfaced!
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
09-02-2014, 07:55 AM | #11 |
Drives: 2013 ZL1 Join Date: Oct 2013
It is a simple brake job, Not seeing any issues with warranty anything myself.
2013 Silver ZL1
09-02-2014, 08:36 AM | #12 |
Drives: xx Join Date: Jul 2014
The faster I wear out something the more fun I have had. Bikes , cars ect.
Kevin
2014 ZL1 , White , 6sp , Recaro Seats , Carbon Hood , Mico Fiber , Nav ect.
2009 Aprilia RSVR 1000 2012 KTM 990R ADV 2013 KTM 500XCW |
09-02-2014, 09:45 AM | #13 | |
then again I don't my own work so by saving $800 a brake job I don't care about waranty. I have put this setut on a 1le with CTSV bake upgrade and he has done a couple track stints and they run out fine. it is just a good way to save some coin expectially if you do use you car at the track and have to do this work more frequent.
09-02-2014, 10:51 PM | #14 | ||
