Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > LT1 (6.2L V8) Powertrain and Drivetrain Discussions
Old 07-09-2014, 11:17 PM   #1
cnock
cnock's Avatar
Drives: 2014 Z51 3LT Stingray Black
Kooks headers no tune cause to lean?
If i install 2in kooks headers and catless midpipe will i be running to lean without a tune or will i be ok? This will be the only install as i have read if you add a inake you will for sure be lean and need a tune to correct A/F ratios.
cnock is offline   Reply With Quote
Old 07-15-2014, 02:04 PM   #2
New C7
New C7's Avatar
Drives: 2014 Corvette Coupe
Maybe. The only way to confirm the A/F ratio is dyno with a wide-band O2 sensor. Probably worth it.
New C7 is offline   Reply With Quote
Old 07-15-2014, 04:55 PM   #3
Corvette7Tuning
Drives: 2014 corvette stingray
You should get a tune when you upgrade to long tube headers. Peak performance will be compromised and you will activate a check engine light.
2014 Corvette Stingray Parts & Accessories
Lowest Prices & Free Shipping!
www.Corvette7Tuning.com
Corvette7Tuning is offline   Reply With Quote
Old 02-18-2015, 05:13 AM   #4
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Correct.........well at least with the wideband. you can do it on the street also with the corvette under actual conditions
Phil
Tampa Tuning is offline   Reply With Quote
