Roto-Fab
Old 07-01-2014, 02:56 PM   #1
slakjak1215
slakjak1215's Avatar
Drives: 2014 1LS
Vinyl Wrap Question
So I have a 2014 LS. The interior panels have that rough texture to them and are plastic. I also was planning on vinyl wrapping the interior panels with white Carbon Fiber but will it stick to this material? Would it be smart to heat the vinyl to take shape of each little bump? I really really want to avoid sanding or buying other panels because that would defeat the purpose of vinyl.
slakjak1215 is offline   Reply With Quote
Old 07-02-2014, 09:35 AM   #2
DesertCamaro
DesertCamaro's Avatar
Drives: Fast
It may stick, but would stick even better on a completely smooth surface. Surface area for sticking is diminished on a bumpy surface. If you're thinking about the door panels, remember when you re-install them the material will pull even tighter, and could cause adhesion issues. Obviously I've been down this road before.....
2014 SS
DesertCamaro is offline   Reply With Quote
Old 07-02-2014, 01:47 PM   #3
luis550
Drives: 2013 2lt
does anyone have a good DIY? i cant find one
luis550 is offline   Reply With Quote
Old 07-02-2014, 04:16 PM   #4
13BlackOut21
13BlackOut21's Avatar
Drives: 13 Chevy Camaro LT
http://www.camaro5.com/forums/showthread.php?t=321844
I don't know if this will help at all?
Live Everyday Like It's Your Last!
13BlackOut21 is offline   Reply With Quote
Old 07-02-2014, 11:26 PM   #5
luis550
Drives: 2013 2lt
I just used this DIY. It is very helpful
http://www.camaro5.com/forums/showthread.php?t=87314
Old 07-03-2014, 05:53 AM   #6
slakjak1215
Drives: 2014 1LS
The problem is, both of those are for the fabric trim, I have the plastic bubble one :(
Old 07-03-2014, 07:17 AM   #7
luis550
Drives: 2013 2lt
My car is a 2ls so I have the trim with the bumps. Just make sure to stretch the material and you will be good to go. I'll try and post pictures for you in a little while.
Old 07-03-2014, 08:12 AM   #8
slakjak1215
Drives: 2014 1LS
You have a double post BTW but that would be great!! close up shots would be awesome and can you feel the texture through the vinyl? any adhesion problems so far? Thanks!
Old 07-03-2014, 09:36 AM   #9
luis550
Drives: 2013 2lt
i cant tell you about durability because i literally just did this. I haven't even done my doors yet, but here is what i have so far.
this is the material i used. 30 dollars on ebay.
just needs to be stretched
final result
Old 07-03-2014, 09:44 AM   #10
slakjak1215
Drives: 2014 1LS
Very nice, is that leather wrap? Just wondering because I wanted to do white carbon fiber vinyl. its gloss so i dont know how much that would stick out.
Old 07-03-2014, 09:52 AM   #11
luis550
Drives: 2013 2lt
its fake leather. I would suggest buying a small sample of the material you want to use and wrap the small piece that i show in the picture. that will give you an idea on looks and texture. I can post pictures of the rest of the Dash when i get home. I'm probably going to redo the long trim piece again because its not tight enough for my taste.
