TireRack
Old 06-19-2014, 04:51 PM   #1
motogplvr
motogplvr's Avatar
Drives: 2010 1SS M6 460rwhp
< $20 Lowes Catch Can w/ drain plug
Just couldn't justify spending $100+ dollars on something like a catch can. Spent less than $20 bucks at Lowes and about $8 at Napa for some fuel hose to make this guy. Drain plug on the bottom. I'll see how it works
motogplvr is offline   Reply With Quote
Old 06-19-2014, 05:53 PM   #2
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
You may want to swap out your 3m pads for something like stainless steel pot scrubbers... I've heard stories of pads like that degrading over time and pieces getting sucked into the engine.
Aside from that, I applaud your creativity!
Jason@JacFab is offline   Reply With Quote
Old 06-19-2014, 06:14 PM   #3
justjoshin
justjoshin's Avatar
Drives: 2010 SW 1SS L99 Camaro
I agree with Jason on using steel wool. I work in the oil and gas industry, and we refer to this as a gas scrubber. Here is a design of it: http://www.ahlundberginc.com/images/bleach16.gif
The idea is to enter the chamber near the bottom and force the gas (speaking of natural gas that we deal with) through a media (steel wool) for liquids to adhere to. They then fall out to the bottom of the chamber to be dumped out.
justjoshin is offline   Reply With Quote
Old 06-19-2014, 08:29 PM   #4
motogplvr
motogplvr's Avatar
Thanks man...yeah just took it apart and wow after less than a couple hours of driving already had a good amount of oil/bs in the can. The 3m pad I think will hold up fine, but I did wrap it with window screen I had left over from something else just to help keep it together. Check it out the bottom cavity where the drain plug is located is already full as well as what you see on the bottom lip. Crazy but hey it works.
I would probably replace the 3m pad every couple of oil changes anyway..they are less than 3 bucks for two full pads which would easily 4 change outs cutting them in half.
Old 06-21-2014, 02:05 AM   #5
xstuntman
Drives: 2012 Victory Red LFX
This is exactly what I was looking for!
Are those nipples 3/8ths? Hose size is 3/8ths too? Don't think I've seen a tee in the commercial kits, just two 90 degree.
Thanks.
xstuntman is offline   Reply With Quote
Old 06-21-2014, 02:21 AM   #6
motogplvr
motogplvr's Avatar
The t barb isn't needed just got it in case. There aren't any lines running from the back of my valve covers on my ss they are both blocked off. Yes the barb ends are all 3/8 and the threaded ends into the base are 1/2.
Sent from my SCH-I545 using Tapatalk
Old 06-21-2014, 03:26 AM   #7
Q'smuscle
Drives: 2011 Camaro VR 2SS/RS & Impala
Nice!
Q'smuscle is offline   Reply With Quote
Old 06-21-2014, 03:27 AM   #8
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
Pretty cool.
newagemuscle is offline   Reply With Quote
Old 06-21-2014, 08:53 AM   #9
BigRed585Lbs
Drives: Sierra and Tahoe
Something just a little more high-tech:
I love the speed shop at Lowe's.
For filter material substitute, I used a/c filter. Heat and fuel resistant. Cheap, too.
Let your imagination be your guide.
BigRed585Lbs is offline   Reply With Quote
Old 06-21-2014, 10:04 AM   #10
motogplvr
motogplvr's Avatar
The point wasn't to just buy an air/water separator like everyone else that does it themselves.
Old 06-21-2014, 03:03 PM   #11
BigRed585Lbs
The point was to save money and not pay billet prices.
Maybe you missed the point I was showing.
Old 06-21-2014, 03:51 PM   #12
motogplvr
motogplvr's Avatar
See how long the filter lasts using an air/water seperator when you are stopping used motor oil. Not long. It will clog.
Old 06-21-2014, 05:22 PM   #13
BigRed585Lbs
I have been using this medium for filter elements since 2009 and haven't had any problems with clogging or degradation yet. I'm not too keen with having stranded stainless steel in the PCV line. No matter how you cut it, there's always some fragments left. But that's just me.
The world's full of choices.
Sorry I bugged your thread.
Old 06-21-2014, 06:12 PM   #14
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
I didn't use steel wool in my catch can, instead I used this:
http://www.amazon.com/3M-Scotch-Brit...3392311&sr=1-4
Larger filaments, stainless steel, and it's actually the perfect size already - just pop the entire thing in.
shibbs is offline   Reply With Quote
