Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > Wheels | Tires | Suspension | Brakes
Old 05-22-2014, 08:30 PM   #1
weaponX
I'm your pusher!
weaponX's Avatar
Drives: 2014 Stingray, 1000HP CTS V, 06 H2
PUR wheels with a 375mm tire on the back :)
Here are the shots from today and some details! These parts are carbon fiber replacement parts, nothing is coated over any OEM parts so there is no hassle of sending any parts in or returning for cores.
The splitter uses OEM bolt holes so no drilling is required. Opposed to just tapering in between the two bumper lips and trying to stair step up, we curved the splitter up between them and angled it down. This made for a better looking transition and also some relief for driveways!
The rocker blades also use OEM mounting holes, so no drilling is required. We brought the blades out right before the rear wheel instead of tapering in. While GM found there to be no benefit from aero stability, that area is highly prone to road rash. Our added area will not only help protect that flare, but also gives the illusion to more of a wide body look than tapering in and looking more narrow.
Our spoiler uses OEM mounting holes as well and is a direct easy install. It looks pretty wicked out the back window and as subtle as I think it is, I get a lot of compliments on this one.
The diffuser is pretty typical but adds a lot to the rear end! It has two vertical vanes added around the exhaust outlet and is a direct replacement.
The hood is the crown jewel to me though! It's 1" taller than the stock hood for a bigger blower, direct port NOS, or just the bulged look. It retains the extractor vent as well as the rear cowl being vented. It also has the Stingray inside the hood above the vent when open. The OEM vent will insert or you can opt for a high quality mesh insert. The radiator duct attaches to the inside as well. We'll be offering carbon louvers and also inner radiator ducting too. I like the mesh look in the hood, but wanted the carbon inner radiator duct under it when looking through, so I put the OEM louvers in and was very happy with the look! The hood comes in a variety of options as it's a true 2 piece hood with an inner and outer. You can do a full carbon inner outer, fiberglass inner/outer to save money, carbon outer/fiberglass inner, or fiberglass outer/carbon inner. Fiberglass is gel coated and ready to paint, Carbon Fiber is standard American 2:2 weave and matches OEM CF weave size.
all of our products are offered in fiberglass as well as carbon fiber. I need to check the time studies on these to see if they're in line with what our CTS V pricing is. I'll do a group buy on some stuff this week to kick this stuff off too
couple more pics of the wing:
weaponX is offline   Reply With Quote
Old 05-23-2014, 09:14 AM   #2
asptroopa1
asptroopa1
asptroopa1's Avatar
Drives: 2014 Corvette
Dang....that looks good (esp since it's Blade Silver HA HA)
asptroopa1 is offline   Reply With Quote
Old 05-25-2014, 10:40 AM   #3
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
I Like the spoiler, much more of a statement than the z51 type. The ,wheels are too busy for me and although I understand the hood sizing, it just looks to me like a car that has not been able to paint it yet....I like the rockers, the ACS looks to be all the rage now, but I don't like their width at the front...like yours and lashways for this....
Old 06-12-2014, 01:05 AM   #4
GQ4Life
Drives: 2010 Camaro SS LS3
how are 375mm not sticking out?
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
c7 aero, c7 diffuser, c7 rims, c7 splitter, c7 wheels
