Old 04-29-2014, 01:55 PM   #1
kutedoctor
Drives: Laguna Blue 2014 Z51
C7 Firmware update question
hello,
I have searched through the forums but the last update I had seen was from December 2013. Does anyone know what the latest firmware release is? Also, is there a difference between the Z51 coupe and regular coupe firmware?
Thanks!
kutedoctor is offline   Reply With Quote
Old 05-02-2014, 09:19 PM   #2
C7Driver
C7Driver's Avatar
Drives: 2014 Z51 Lime Rock Green
Don't have an answer for your questions but I hear the 2015 model year will not require a trip to the dealer for "firmware" updates. Updates are supposed to be done over the air. Maybe someone who went to the Bash can chime in.
C7Driver is offline   Reply With Quote
Old 05-02-2014, 10:48 PM   #3
BRCC
BRCC Webmaster
BRCC's Avatar
Drives: 2017 GS 3LT Sterling Blue/Gray Int
Originally Posted by kutedoctor View Post
hello,
Thanks!
There are many Controllers within the C7 system that can be updated, basically for each VIN the Calibration history needs to be checked via TIS to determine the software level, actually GM assignes a part number to each software update by system/subsystem. As an example Controller K71 is the Transmission Control Module Programming (Auto) and 5 part numbers relative to the subsystems.
So the answer to your question is you need to have the dealer verify your software based on configuration. Yes, Z51 should be different due to eLSD and in most cases MSRC.
BRCC is offline   Reply With Quote
Old 05-06-2014, 11:22 AM   #4
kutedoctor
Awesome! Thanks for your replies
Old 05-06-2014, 04:11 PM   #5
kutedoctor
Infotainment updates
I have heard that you can use the website link GM sends you to obtain software updates for the Infotainment system. Is this correct?
Old 05-06-2014, 04:21 PM   #6
laborsmith
Drives: 1969 Corvair, 2018 Camaro T4 RS
Not for Chevrolet at present.
I have read rumors that it may be possible in the future.
Laborsmith
laborsmith is offline   Reply With Quote
Old 05-07-2014, 09:48 AM   #7
kutedoctor
Thank you
Laborsmith
I would figure that it would be possible with a USB port. Since most everything electronic now days is updated through that. Thanks for the info!
