Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 04-26-2014, 11:26 PM   #1
AmericanMuscleCars
Teenage Dream Camaro
AmericanMuscleCars's Avatar
Drives: A Visually Stunning Camaro
High flow cats Vs. No Cats
Hey guys I was looking at bolt ons and I saw that high flow cats add a good 15 horsepower. Would I be able to accomplish this by just cutting them off and replacing them with piping? Thanks guys!
White shoes at the black show
AmericanMuscleCars is offline   Reply With Quote
Old 04-27-2014, 07:52 AM   #2
BlackoutLFX
BlackoutLFX's Avatar
Drives: 2012, Black 2LS
I don't know if you have emissions testing in NONYA. LOL. Yes you can simply cut them off. You will need to adjust the tune to avoid cels and you will not be able to pass emissions tests. You might also smell gas fumes without the cats.
Nytrex 100 hp nitrous triple threat system, NytrexAccu-pressure bottle heater, HP tuners, K&N Typhoon CAI, MACE 6mm MI, Solo Performance high flow cats, Flowmaster American Thunder cat back exhaust system, BMR subframe connectors, BMR tunnel brace, BMR lowering springs, BMR Xtreme Anti-roll bar rear, Hotchkins Strut brace, SS/LS3 3.45 LSD, Axles, and hubs, Elite Engineering catch can, B&M Supercooler transmission cooler, FTI 3200 Stall.
BlackoutLFX is offline   Reply With Quote
Old 04-27-2014, 08:04 AM   #3
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
It might be raspy too, and you'd need a resonated x or something. Power, though, just removing all cats is the way to go.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
DSX_Camaro is offline   Reply With Quote
Old 04-27-2014, 01:20 PM   #4
AmericanMuscleCars
I live in Florida so there are no emissions here, I have a borla axle back so I don't think there will be rasp, do you think a dyno tune would help the engine light go off, because of the o2 censors. Will cutting them off pass as high flows?
Old 04-27-2014, 09:59 PM   #5
BlackoutLFX
the o2 sensors can be set to not to report a cel. doesn't need to be on a dyno to do that.
Old 04-27-2014, 10:18 PM   #6
AmericanMuscleCars
Gotcha, and how bad will the gas smell be? Will it get stuck in all my cloth interior on the inside?
Old 04-27-2014, 10:35 PM   #7
BlackoutLFX
Shouldn't be horrible. Shouldn't smell it inside with windows up
Old 04-27-2014, 10:53 PM   #8
AmericanMuscleCars
Awesome, I appreciate the info!
Old 04-27-2014, 11:19 PM   #9
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
I wouldn't cut your stock pipes - have new ones fabbed up at an exhaust shop. It's always nice to have stock stuff just in case you decide to sell it.
shibbs is offline   Reply With Quote
