Old 11-30-2013, 09:44 PM   #1
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
20x10 on all 4 corners?
+35 should work on all 4 corners, correct? With 285/35
Nutro is offline   Reply With Quote
Old 11-30-2013, 10:04 PM   #2
JewelSS
Norcal Camaros
JewelSS's Avatar
Drives: 2010 Red Jewel 2SS L99
Should be ok, you may have some tire rub in the front when corning depending if your lowered or not. I would go with 19's and 295's all around myself
Blaque Diamond Wheels BD23's 20x10, Hankook V12 275, AAC footwell lighting, Switchback LED's, AAC Mailslot scanner, AAC underhood, grill & underbody led lighting, AAC Plasma fogs, Eagle eye HIDs, RJT Painted calipers, RJT painted engine bay, Viteese Paddle Shifters, CFD Hurst style Shifter, RJT painted speedo & gauge trim, RotoFab CAI, TSP 2" Headers with full 3" XS Power exhaust, Granatelli Slotted rotors & Hawk HPS pads, ACS Side Rockers, ACS Front splitter, ZL1 Grill, Havoc Rear diffuser, BMR 1.4 Springs, BMR Strut tower brace, BMR F/R Sway Bars, BMR Trailing Arms,
JewelSS is offline   Reply With Quote
Old 12-01-2013, 08:47 AM   #3
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
275s and that offset worked for me on my old set up. The guy that bought them from me did 285 toyos I think.
-John S.
grocerygetter is offline   Reply With Quote
Old 12-01-2013, 08:48 AM   #4
midnighter
Drives: nothing
Say goodbye to the paint on your quarter panels.
Old 12-01-2013, 09:43 AM   #5
L99CAMA2011
L99CAMA2011's Avatar
Drives: One of the baddest handling Gen 5s
Perfect setup with TSW Nurburgrings if you are running BF Goodrich G force rivals you will experience rubbing on front strut a bit but not much if you are not cambered too much. No rubbing issues.
L99CAMA2011 is offline   Reply With Quote
Old 12-01-2013, 09:46 AM   #6
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Isn't this the 1LE setup (except wider wheel on back)? Why wouldn't it work with aftermarket wheels and tires?
AG1LE is offline   Reply With Quote
Old 12-01-2013, 10:46 PM   #7
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
It's all about the offset's.....
So Cal Camaro is offline   Reply With Quote
Old 12-02-2013, 06:10 AM   #8
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
I have 20x10s in all 4 corners with an offset of +35 and run 275/40/20s and have zero issues, although I am not lowered yet.
Old 12-02-2013, 10:00 AM   #9
SLEEPER SS
Drives: 2010 2SS/RS
Lol some people make me laugh. It's all about the offset and proper tires. I'm running 20x10.5 all around. Running 295/35 in the front with no rubbing nothing no problem doing full u turns. Oh yeah and did I mention I'm dropped 1.5in all around.
SLEEPER SS is offline   Reply With Quote
Old 12-02-2013, 11:49 AM   #10
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
Nutro, I have +35 with PSS 285/35s all around. I am lowered 1 inch but I have coilovers which give a little more clearance between the strut and tire. I cannot verify for sure with stock struts if the fronts will clear with a 285. My gut says it will not or be too close for comfort. Also you won't be able to get more than the OE camber adjustment from the front, if you care.
I had this setup with both Pedders and the new Pfadt coilovers. With the Pedders I had about 1/2" between the strut and tire with an OE alignment. The 1LE/ZL1 +23 offset should work on the fronts. Not sure what wheel you are considering, but if custom offsets are available I would do that. I chose off the shelf TSW.
bannonm is offline   Reply With Quote
Old 12-02-2013, 07:16 PM   #11
Witchdoctor92
Witchdoctor92's Avatar
Drives: 2012 1SS Black with white rally str
I am running 19X10 with +30 offset and it is about 3/8" clearance on the strut up front. It will be close. I think all the Forgestars come with custom offsets and they aren't too expensive.
It's good to be the King.
Witchdoctor92 is offline   Reply With Quote
Old 12-07-2013, 02:58 PM   #12
FRSTR90
FRSTR90's Avatar
Drives: 2010 Camaro 1SS/RS, 1973 Corvette
20x10 35mm offset, 275/40/20 Nitto INVOs w/ Pfadt ZL sways and drop springs.
There is no rubbing up front, but it is close. It handles like a totally different car. All SS(s) should have come this way from GM.
FRSTR90 is offline   Reply With Quote
Old 12-10-2013, 05:26 PM   #13
tadams72
When is enough ever...
tadams72's Avatar
Drives: 2006 Silverado 2500HD CC/SB LBZ
Location: Residence: Chula Vista, CA Home: Billings, MT
I just picked up some TSW Panorama 20x10 35mm offset and just test fit the fronts without tires. No way this is going to fit without a spacer. I've got .17" clearance between the rim lip and the strut. I am dialed in for more negative camber which is probably a contributing factor. Not sure what I am going to do yet. I purchased to run a square setup for track days and pick up some badly needed grip. Scored a good deal and turns out the bronze Panorama is actually a good looking wheel. Probably going to get the longer studs and run a 10-15mm spacer to get a ½ to ¾ inch clearance. Hmmm, what to do?
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing
tadams72 is offline   Reply With Quote
Old 12-11-2013, 12:23 PM   #14
Nutro
Nutro's Avatar
Haha that's the exact setup I was going to go for. Hmmm I'm not running too much neg camber so maybe it will work. If not, maybe a 5mm spacer would suffice without longer studs.
