Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > Cosmetic Modifications
Old 11-11-2013, 11:51 PM   #1
showstopper
Drives: 2010 RS/SS
Fuel Rail and Plenum Cover Removal
We have had quite a few of our customers request instructions for removing the fuel rail covers and plenum cover after purchasing our smoothie versions. Here is a quick session on how to do so.
Plenum Cover
http://showstopperaccessories.com/pr...num-Cover.html
Fuel Rail Covers
http://showstopperaccessories.com/pr...il-Covers.html
The fuel rail covers are just snapped in place using a rubber grommet style fastener. Start of by lifting upward more towards the plenum side and they will unsnap without using too much force.
Then, once you remove the fuel rail you will notice a wiring harness that is fastened to the plenum cover. They are just zip ties that are snapped into the plenum. So if you wiggle the zip tie upward, it should slowly come out. Sometimes a tool is needed to get this started. This is what it should look like once removed.
The next step is to remove a total of four 10mm bolts that hold the plenum in place. These also have a nipple at the top in which your fuel rails snapped into.
Lastly, there is one wiring connector that will need to be disconnected in order to lift the plenum off. Once this is done, you are ready to lift the plenum off.
Reverse the steps to re install everything. If you have any questions, feel free to pm me.
showstopper is offline
Old 11-12-2013, 10:57 AM   #2
GunnyG
Da WHALE
GunnyG's Avatar
Drives: 2014 Stingray, 2015 Panamera 4
I was wondering how to get this thing off.
Project MantaRay...Underway
GunnyG is offline
Old 11-12-2013, 11:12 AM   #3
Stingray
just can't get enough
Stingray's Avatar
Thanks, showstopper! Quite simple after all.
Stingray is offline
Old 11-14-2013, 08:43 PM   #4
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
great instructions - I was able to change my plenum 15 min - two things - a panel popper (see amazon) makes the harness detach easier, and it takes a deep 10mm socket to get off the plenum bolts....
gloss rails next week.
Glen e is offline
Old 11-19-2013, 06:26 PM   #5
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
That fuel rail and plenum cover is the first thing I do when I get mine. Looks absolutely outstanding.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline
Old 11-19-2013, 09:25 PM   #6
showstopper
Drives: 2010 RS/SS
Looks good. Nice and clean
Old 11-23-2013, 03:41 PM   #7
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
added the rails...love the color:
done in the color of my car with red accents...a HUGE diff from the stock ones above...
Both of these alcohol wiped and then treated with Dodo "tropical red mist" wipe on seal - made for hi temps...
Glen e is offline
Old 01-26-2014, 11:45 PM   #8
C7Driver
C7Driver's Avatar
Drives: 2014 Z51 Lime Rock Green
Thanks for the post. Now I know how easy it will be to remove the covers. This is gonna cost me money.
C7Driver is offline
Old 06-15-2014, 10:56 AM   #9
halt00
Drives: 2014 Corvette
Does anyone know exactly how to remove the wiring harness? I have everything apart but I just can't seem to figure out the locking mechanism.
halt00 is offline
