Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > Wheels | Tires | Suspension | Brakes
Old 09-24-2013, 11:37 AM   #1
R6P
R6P's Avatar
Drives: 2010 Camaro
Z51 brake cooling rings
Just got this message from gm...
2014 Corvette Stingray Z51 Brake Rotor Cooling Rings
Attention: Sales Personnel, Service Advisors, Service Managers, Service Technicians and Pre-Delivery Inspection Personnel
The Corvette Stingray Z51 will arrive at the dealership with a package of aluminum rings and wire. These are called out as brake rotor cooling rings. These rings are to be provided to the customer and are not to be installed during the PDI process. The cooling rings are for customer use if they elect to use the vehicle in a competitive driving event. The directions are outlined in the 2014 Owners Manual under "Competitive Driving". A bulletin is being prepared to explain this to the dealerships and it is also being noted in the Pre-Delivery Inspection worksheet. The rotor rings are for off road use only and must be installed to prevent brake fade in competitive events.
Rotor Cooling Ring
Caution: Do not leave rotor cooling rings installed after a track event, as this can cause corrosion with long-term use. Rotor cooling rings are for race track use only. Race track driving without the rotor cooling rings may result in brake pedal fade.
Installation:
1. Remove the front wheels.
2. Cut three 150 mm (6 in) lengths of safety wire specified to T304 Stainless Steel, 0.041 in nominal diameter, not included.
3. Form each into a U shape with a 20 mm (0.75 in) flat area in the center of the wire.
4. Place the rotor ring in the gap between the rotor brake plate and rotor hat, with the holes on each side of the rotor spoke on the outboard side of the rotor.
1. Place the U-shaped wire through the holes in the rotor cooling ring.
2. Bring the ends of the wire tight around the corresponding rotor spoke.
3. Twist the safety wire into six to eight twists per inch.
4. Bend the twisted wire so it is flush with the inside of the rotor ring to prevent contact with the caliper or brake hoses.
5. Verify that the rotor rings and safety wire do not contact any other components.
6. Reinstall the wheel using the specific lug nut torque. See Capacities and Specifications in SI.
If additional brake cooling is required, the grill mesh in the lower corners of the front grill in front of the brake duct can be removed. This is not reversible, and a replacement grill will not be covered by the warranty. If this is done, it is recommended that the gap between the fascia and the cooling duct be taped over.
R6P is offline   Reply With Quote
Old 09-25-2013, 10:23 AM   #2
Rogan
No Pain No Gain
Rogan's Avatar
Drives: Yellow 5th Gen 2SS RS
Waiting for the youtube version.
2010 2SS/RS/L99 - Headers/CAI/SWAYs/CoilOvers/Tune/Steel Braided Brake Lines/Frozen Slotted Rotors
Rogan is offline   Reply With Quote
Old 09-25-2013, 10:50 AM   #3
occar
Drives: n/a
They just look like a flat ring in the pictures which makes little to no sense. Does anyone know what they actually look like?
occar is offline   Reply With Quote
Old 09-25-2013, 12:14 PM   #4
R6P
R6P's Avatar
Drives: 2010 Camaro
Sorry, no actual pics yet. Our first Stingray just arrived, no Z51 pkg :(
Old 09-25-2013, 02:02 PM   #5
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
Its the round ring the arrows in the photo above are pointing at. The block off the air holes there to funnel the air out the ends of the rotors. This somehow is suppose to cool better than having the holes open. Seems very dumb to me but want be able to test it till Nov 23 when I hit road Atlanta with it.
Nationwide Turf
"artificial turf factory"
lawdogg149 is offline   Reply With Quote
Old 09-30-2013, 07:32 PM   #6
dgerstel
dgerstel's Avatar
Drives: 2014 Corvette Z51 2013 Camaro ZL1
With the openings between the rotor and the hub not blocked by the cooling rings the air supplied by the brake cooling ducts, just blows thru and doesn't do much cooling. With the openings blocked, the air is forced thru the vanes in the rotors, cooling them, like in disc brakes with one piece discs.
Dale
2014 Corvette
Z51, 3LT, Torch red, red interior, Black Wheels, Red Brake calipers, Auto, Mag ride, performance exhaust, Exposed Carbon fiber roof, Carbon Fiber dash, Black mirrors and spoiler
dgerstel is offline   Reply With Quote
Old 09-30-2013, 09:30 PM   #7
bnall40
Drives: Z51 3LT, 2009 Pilot, 2012 Ody Tours
The info above states that the rings are to be provided the customer but not installed...
Do you read that to mean at no additional cost? Seems as though they would be as the Z51 is advertised as "Racetrack Ready"
bnall40 is offline   Reply With Quote
Old 09-30-2013, 09:36 PM   #8
occar
Drives: n/a
They come with the z51 package. The owners manual talks about them and specifies this.
Old 11-19-2013, 04:29 PM   #9
thespymaster
thespymaster's Avatar
Drives: C7 / ZL1 / SS / trucsk
My dealer had no clue what they were!!!!!!!!
2014 C7 Stingray 3LT/Z51
2013 Camaro SS
2012 Camaro ZL1 - 850 HP
2015 GMC Denali 3500HD 4x4
2012 GMC Sierra 3500HD 4x4
thespymaster is offline   Reply With Quote
Old 11-19-2013, 05:06 PM   #10
Stingray
just can't get enough
Stingray's Avatar
Mine are still sealed in the plastic... will try to post pics later.
Old 11-19-2013, 10:24 PM   #11
GQ4Life
Drives: 2010 Camaro SS LS3
I can post pics of them but I dont know how they install really..
But I can see how they work. Brake ducts will cool the rotors too much on highway use with not much braking. Cold brakes dont stop well, so you allow air to flow thru and not cool the rotors as much on the street. This way the brakes heat up and stay a normal operating temp. More agressive track pads need heat to be able to stop good...
Pics of cooling rings
to compare size..
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 11-19-2013, 11:07 PM   #12
Stingray
Stingray's Avatar
Yup that's it. Thanks. Pretty neat & effective feature!
