08-21-2013, 09:58 PM | #1 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
The testing of Vmax ICEOLator & ported LLT throttle body
As many of you know, I sell a ton of Vmax motorsports parts because they are located right here in Tampa. Today at PowerTech performance in St. Petersburg tested a completely stock LLT V6 motor on a Camaro which was stock from the air intake box to the exhaust tips
As you know, there are no quality calibration platforms to tune the LLTs with, so the aftermarket go fast parts are being made which don't need tuning Todays test car was pulled into the dyno bay and shut off while being strapped her down ( Big thanks to JC 615 for letting us use her green monster). After the Camaro was tied down and centered on the DynoJet 248, we did two pulls and shut the car down to install the ICEOlator and throttle body. We followed the instructions we provide and install the Vmax ICEOlator and ported throttle body. Two deviations we did from the instructions was to skip adding the two rear bolts behind the manifold ( which is a choice in the directions) and a 4 inch bracket plate we didn't install which stabilizes the manifold to the block. Since the manifold sits 3/8" higher, the bracket became about a 1/4 short. Forcing it to work would crack the casing and the bracket provided no advantage . Ill write up more with pictures, but don't just look at the peek of or 10 RWHP and 14 RWTQ gains in this graph. Look how the power spreads on the run 2 and the run 4 with the ICEOLator and ported throttle body when it hits 4200 RPMS. that was a shocker. I'm a believer because we showed 30 RWHP gains and 38 RWTQ. Those are solid gains between 3200 and 5500 RPM range. The install was 45 minutes more to follow Phil Last edited by Tampa Tuning; 08-22-2013 at 08:06 PM. |
08-21-2013, 10:42 PM | #2 |
Jan
Drives: 2010 Camaro 1LT Red Jewel tintcoat Join Date: May 2010
I knew my butt dyno was feeling some good gains! Very cool. I can't wait to get a new dyno on Ruby! Thanks for sharing this. Looking foward to seeing more.
This thread would probably get more hits in the V6 LLT section. Just sayin'.
08-22-2013, 08:23 PM | #3 |
We started with the LLT go kit consisting of the Vmax ported LLT throttle body and the Black ICEOlator. We didn't use the top spacer for our test. We just bolted on the ICEOlator and throttle body. The kit comes with instructions, but Ill post them in this thread.
JC615's completely stock LLT Camaro on the DynoJet 248 |
08-22-2013, 08:36 PM | #4 |
[IMG] Remove gasket and snip the nipples we did not use a second gasket so the stock bolts are long enough and do not need to be replaced when bolting down the manifold Half way done Last edited by Tampa Tuning; 12-22-2013 at 08:12 PM. |
08-22-2013, 08:52 PM | #5 |
ICEOlator in place and it stays there pretty natural while your adding silicon to the manifold.
Now was the best time to add the ported vmax throttle body having two sets of hand on the manifold made it easier to set on top of the block and lining up the bolts Start to reconnect the hoses Last edited by Tampa Tuning; 08-23-2013 at 05:06 AM. |
08-22-2013, 09:02 PM | #6 |
08-22-2013, 09:06 PM | #7 |
08-23-2013, 10:59 PM | #8 |
Jan
Nice! Wish I had that when I did mine. Imagine the gains if that baby had a good cold air intake too. I was just looking over my time slips & noticed my top speed at the end of the quarter mi is over 2 mph higher since I got the black iceolator & ported throttlebody.
08-24-2013, 06:50 AM | #9 |
I had to test it before I pushed it for sale.
Another great bang for the buck. I saw your you tube video of the install and I said I have to try this to see if I want to sell them..........Loved it! The owner in another thread said the car really feels difference now and the dyno backed up why. Phil Last edited by Tampa Tuning; 08-24-2013 at 08:04 AM. |
08-27-2013, 06:03 PM | #10 |
I match ported my intake holes to the ICEOlater made a big difference.
08-28-2013, 05:59 PM | #11 |
I have a ported manifold in the garage, but I didn't think it was fair to install it. I just wanted to show the gains from the ICEOlator and CnC throttle body.
But yes a ported manifold to allow more flow would help. Whatever you do to get more air in more air out makes HP. |
09-17-2013, 10:56 AM | #12 |
Barossa's handler
Drives: 2LT/RS RJT Join Date: Mar 2010
Any ideas of what just he Ice-olator does in terms of performance?
SLP's GTA Master Specialty Vehicle and Master Parts Dealer
09-18-2013, 09:32 AM | #13 |
Camaro Corvette GTO Truck Tuner in Tampa Orlando Brandon
I havent tested just the ICEOlator alone, but im sure you'd have positive gains because how it seperates the manifold from the top of the block to reduce the heat soak.
09-18-2013, 04:38 PM | #14 |
Barossa's handler
Thanks. I just got one in and am going to install shortly. I didn't get a TB yet so I was wondering what to expect in way of noticeable gains.
