dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 07-23-2013, 04:40 PM   #1
SPOOKYGUNNER
ROCK
SPOOKYGUNNER's Avatar
Drives: 2013 ZL-1 TRIPLE BLACK VERT
17" vs 20" DRAG RADIALS
I am debating between 17" and 20" drag radials for my 2013 A6 ZL1. I am looking for info from anyone who has used either size.
PRO VS CONS
THANKS
WHEN ONE AMERICAN IS NOT WORTHY TO BE FOUND...THEN WE AS AMERICANS HAVE LOST. POW/MIA YOU ARE NOT FORGOTTEN
SPOOKYGUNNER is offline   Reply With Quote
Old 07-24-2013, 07:34 AM   #2
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
Just put a set of Mickey Thompson ET Street II's on the stock 20 inch wheel, and am loving it. I cannot get these tires to spin! (On the streets) Haven't been to the track yet. The only downside is, with a wear rating of "0", they're not gonna last long. Oh, and mine are turning on the rim. Not much, only an inch or so after some spirited driving. But something that will have to be addressed at the track, I fear.
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 07-24-2013, 03:46 PM   #3
SPOOKYGUNNER
ROCK
TIRES SHOULDN'T TURN ON THE RIM..BETTER CHECK BEFORE YOU GO TO THE TRACK AS THEY WILL PROBABLY TURN MORE AT THE TRACK NOT SAFE
Old 07-24-2013, 07:46 PM   #4
Blown355
Blown355's Avatar
I know they're not suppose to. They are definitely slipping though.
2017 ZL1
A10
Redhot with stripe
Old 07-24-2013, 08:07 PM   #5
Blainne
Drives: 2004 SRT10
Tire pressure to low? Only thing I could see to cause the rim to slip on the tire. The tire pressure is what holds the tire to the wheel unless you have too much wheel for the tire.
2011 135i (sold)
2004 SRT 10 Viper (sold)
2006 Z06 (sold)
1970 Mach 1 (sold)
2007 GT500 (sold)
+20 others
Blainne is offline   Reply With Quote
Old 07-24-2013, 08:13 PM   #6
2010Slowmaro
5.0 lol...
2010Slowmaro's Avatar
Drives: 2010 Camaro 2SS M6
Can the ZL1 even fit a 17" rim stock? The SS can't, I don't think the ZL1 would be any different...
2010 2SS M6 SWG built turbo car
2000 Z28 A4
Custom tuned by a Skinny White Guy
2010Slowmaro is offline   Reply With Quote
Old 07-24-2013, 09:10 PM   #7
Blown355
Blown355's Avatar
30 psi. And I haven't even tried launching it yet. This is just some spirited driving on the way to work and back. Gonna re mark it tomorrow, and see if it moves any more. If it does, I'll try adding a few more lbs of air pressure and see if that helps.
Told you these tires were sticky.
2017 ZL1
A10
Redhot with stripe
Old 07-24-2013, 10:18 PM   #8
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
Ya they fit. Waiting for an opportunity to try them at the track to see if a hard launch causes a conflict of space.
Trackman is offline   Reply With Quote
Old 07-24-2013, 10:21 PM   #9
Supercharged SS
Drives: 2010 Camaro
A 17" bogart bolts right on. Didn't even to tie back the E brake cable.
Supercharged SS is offline   Reply With Quote
Old 07-24-2013, 10:36 PM   #10
PMJ
Seeking 9s on M6...
PMJ's Avatar
Drives: 2012 2SS/RS LS3 aka "BlackWidow"
PRO VS CONS
THANKS
For track or everyday? 17" will definitely be better for launches and the 17" wheel and tire should be significantly lighter, so better acceleration. The 20" will handle better in turns...likely a better daily driver.
Who installed them? Did they use the soapy water to put them on the rim, that will cause slipping w/high torque. I think all drag radials and slicks are recommended to install dry to prevent slipping.
I'm not a tire expert, but this is what I've picked up along the way...
PMJ is offline   Reply With Quote
Old 07-25-2013, 12:45 AM   #11
ace32x
ace32x's Avatar
Drives: 2013 ZL1
i have 18s up for dirt cheap
C6Z06 400ci, twin gen 2 promod 88's,th400, Alky car
ace32x is offline   Reply With Quote
Old 07-26-2013, 12:33 PM   #12
SPOOKYGUNNER
ROCK
17" WOULD BE DRAG RACING ONLY. BOTH BOGARTS AND WELD MAKE WHEELS THAT WILL FIT . MT AND HOOSIERS HAVE 325/45/17 DRAG RADIALS
Old 07-26-2013, 03:37 PM   #13
Dega Man
Drives: ZL1
I am running my Mickey ET Radials at 18psi have not had the spin on the rim problem.
Dega Man is offline   Reply With Quote
Old 07-26-2013, 05:54 PM   #14
Blown355
Blown355's Avatar
First, sorry for hijacking your thread spookygunner.
They did use soap while installing the tires on the rim. That's probably the problem. I think after a few heat cycles it will fix itself. I'll give it a week or so, then post the results.
2017 ZL1
A10
Redhot with stripe
