TireRack
Old 05-27-2013, 09:19 PM   #1
TheBandit18
TheBandit18's Avatar
Drives: 2011 Camaro 2ss M6
Night fury push rod size?
Im getting close to buying the night fury cam kit. Do i need to use the 7.425?
I only have headers and cai so no head work.
TheBandit18 is offline   Reply With Quote
Old 05-27-2013, 09:53 PM   #2
blake-b
blake-b's Avatar
Drives: 2009 ZR1
You will need to measure after the cam is installed. You could also have 7.400 (stock) and 7.425 on hand so there is no downtime if it turns out either of those will work. Perhaps people with similar mods and the night fury cam will post in here what pushrod length they used to give you an idea of what you could have on hand.
When I changed cams (custom grind) and heads (PRC 260) I asked what pushrod length was most used when using the new heads. I was told 7.500 so I bought a set to have on hand. That turned out to be the correct length I needed after measuring.
The company selling the you the cam should have some knowledge of what the most commonly used length for the cam is but you still need to measure.
Old 05-27-2013, 09:55 PM   #3
driyac
driyac's Avatar
Drives: 2012 45th Anniversary 2SS
ls3 with no modifications is 7.425. This has been confirmed by lethal for 99% of their builds.
from a pm
"Im 99% sure the 7.425 is the right ones. We use it in 99% of all the LS3's lol
Nick"
driyac is offline   Reply With Quote
Old 05-27-2013, 09:57 PM   #4
TheBandit18
Ok. thanks guys!!
Old 05-27-2013, 10:00 PM   #5
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
You could go ahead and order the size they tell you but I would double check the size needed just to be sure.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
VADER SS L99 is offline   Reply With Quote
Old 05-27-2013, 10:01 PM   #6
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
I bought 7.4s from TSP just in case the 7.425s were too big, but the 7.425 were just perfect.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 05-27-2013, 10:12 PM   #7
TheBandit18
Ok thats why i came on here since there should be a lot of people here with this cam and lethal racing is having the kit for $799 and they might finish the sale tonight.
Old 05-28-2013, 09:28 AM   #8
SC2150
Drives: 2012 Camaro RS, RX supercharged
110% agree. Although most of the time the vendor will suggest a close estimate, to do it 100% right, you have to measure.
SC2150 is offline   Reply With Quote
Old 05-28-2013, 11:18 AM   #9
TheBandit18
Ok I did a search and one of the guys the work at lethal racing said 7.425.
Old 05-28-2013, 12:19 PM   #10
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Back when I bought mine, they didnt even offer other sizes as an option. I just went on their website and now they have a bunch of good options. Good for them!
Old 05-28-2013, 08:21 PM   #11
TravisTrout
Hot roddin' Steamfitter!
TravisTrout's Avatar
Drives: 2010 Camaro 2SS/RS M6 CGM
Just ordered my nightfury package today, with the 7.425's as well.
I can hardly wait to get it installed... Mustanks of Washington Beware!!!!
TravisTrout is offline   Reply With Quote
Old 05-28-2013, 10:32 PM   #12
TheBandit18
ordered mine the 27th so just waiting for it to get here then have to get a little more money for the tune. and then breaking into the engine!!
Old 05-29-2013, 08:38 AM   #13
BLACK10
BLACK10's Avatar
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60'
as Tracey stated, the proper way is to measure, but in the LS3 the 7.425" pushrods are what 99% of them use when only the cam is changed(NightFury). The L99 usually takes the 7.400.
Thanks for purchasing the NightFuRY CAM!
BLACK10 is offline   Reply With Quote
Old 05-29-2013, 11:24 AM   #14
kevint
Drives: 2013 1SS
from a pm
Nick"
0.99*0.99=0.98 => 98% I'm no longer confident in this advice. /sarcasm
kevint is offline   Reply With Quote
