05-15-2013, 08:35 PM | #1 |
Drives: 2010 Camaro V6 Join Date: Mar 2013
Need a new audio system. Any suggestions?
I really hate how the stock audio sounds like. Especially with the type of music I listen to (hiphop and dubstep) I know nothing about audio so what do you guys recommend? I rather have a punchy bass
05-15-2013, 08:44 PM | #2 |
Drives: 2012 45 Anniversary Vert Join Date: Apr 2012
do you have any more specifics on what parts of the kit, what you want out of it etc are?
What type of music do you listen to? Country? Rock? Blues? all the above? Do you want the sound to be super great, or are you looking to just load up on Bass to the point your roof bowes out? Are you looking for a listing of what others have in now? Just saying, its kind of a general statement, and depending on what you want to end up with, people could have a dozen configurations they list on here, all not what your looking for. |
05-15-2013, 10:44 PM | #3 | |
05-15-2013, 10:49 PM | #4 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
I just added a amp and sub.
See specs in signature below.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
05-15-2013, 10:55 PM | #5 |
Amp and sub will give you the deep bass you want pretty easy to install for only a few hundred dollars. Unless you go crazy insane with it.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
05-15-2013, 11:43 PM | #6 |
Drives: 2013 CRT 2LT RS Join Date: Mar 2013
I just had the Rockford Fosgate 10" Punch 300 installed today. For the money it cant be beat. It's a powered sub and compliments my BA Premium perfectly.
So far I love it, for hip hop I'd get the 12" and I've seen it for under $200 |
05-16-2013, 01:49 AM | #7 |
Helping Build America
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD Join Date: Aug 2008
My first suggestion would be to look in the audio section of this forum. There are hundreds of threads about subs and amps that would give you ideas about what kind of equipment to buy and what price range you want to get into.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
05-16-2013, 07:08 AM | #8 |
Drives: 2011 Camaro Join Date: Apr 2012
DB Drive. Powerful and not too expensive
05-16-2013, 11:11 AM | #9 |
Drives: 2010 Camaro 1SS IOM M6 Join Date: May 2012
The most important question: What's your budget?
05-16-2013, 11:55 AM | #10 |
My budget is around $300 - 400 . Are there any brands I should stay away from?
05-16-2013, 12:33 PM | #11 | |
Rockford Fosgate Punch P300-10 - $200
http://www.amazon.com/Rockford-Fosga.../dp/B007AQ2W2Q Fit's in the trunk without modification. Well under budget. Almost no hassle to install, it'll get you the bass you are looking for. Might want to spend $50 for a small amount of CLD like Dynamat or Damplifier for the decklid for when you introduce the extra bass. Checkout this thread: http://www.camaro5.com/forums/showthread.php?t=278828 Youtube video(not mine): I'd recommend a Scosche 8-gauge wiring kit. Scosche makes their power cables from Oxygen Free Copper, is fairly true to AWG size, and doesn't jack up the pricing on it. http://www.walmart.com/ip/Scosche-68...-Amps/14667122 You won't find the 8ga OFC alone for what they charge for the whole kit. Last but not least, while you're at Wal-mart, grab some 3M T-taps to plug your speaker level inputs into the sub. Shouldn't be more than $10 for that |
05-16-2013, 02:30 PM | #12 | ||
+1 on the Dynamat |
05-16-2013, 03:25 PM | #13 |
Drives: 2013 GAZ 2SS/RS Join Date: Feb 2012
I have a pair of Rockford Fosgate Punch 12" shallow P3's in a slim box, and a T400-2 amp, and I'm really happy with them. I listen to Dubstep too, and knowing bass music, I would really recommend getting 12's over 10's so they can hit just a bit lower, as most dubstep and hip-hop have bass sounds that you would otherwise miss.
Rockford Fosgate subs were made for Dubstep.
If you see it, get it, for tomorrow it may be gone!
