05-15-2013, 05:42 AM | #1 |
Drives: Black ZL1 Join Date: Apr 2013
How Many Have CAI
My buddy, archaic as he is, saw my Rotofab cold air intake and said "That's what the ricers put on their cars." Honestly, he hasn't been around the performance community since about 2003. I explained that any modded Camaro now was going to have had that done. Not necessarily Rotofab, but some sort of cold air intake
So how right was I, how many people, except the ones that have kept their cars bone stock, have a cold air intake on it.
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
05-15-2013, 05:44 AM | #2 |
It's in the hole!
Drives: '11 2SS L99 SGM, '18 2SS, M6, HWSE Join Date: Apr 2011
Go to any car show, you won't see many 5th gens without a cai.
05-15-2013, 05:48 AM | #3 |
I'm about to, Vengeance Racing in Atlanta open house this coming Saturday, and the following weekend F Body Gathering in Atlanta and also back to Vengeance Racing
05-15-2013, 05:51 AM | #4 |
Drives: 2000 Camaro SS Join Date: Feb 2010
The first step in extracting more power from an engine is getting more air in it with greater efficiency.
05-15-2013, 05:59 AM | #5 | |
Drives: Eve - 2011 Camaro 2SS/RS Join Date: Apr 2012
05-15-2013, 06:56 AM | #6 |
Drives: 45th Anniversary 2LT/RS Coupe Join Date: Sep 2011
The red stripe on my ride makes it go faster.
05-15-2013, 07:03 AM | #7 |
Drives: Really Slow Join Date: Apr 2010
well shit, I thought you meant CAI the brand, not just a cold air intake...so I voted no, but I do have a roto-fab as well.
in all honesty, are these really cold air intakes, or short ram intakes?
05-15-2013, 07:07 AM | #8 |
my car is bone stock. no cai here
2018 2SS hot wheels convertible
05-15-2013, 07:10 AM | #9 |
Drives: 2010 Camaro SS, 2018 Colorado Join Date: Nov 2009
First thing I did to the car. Air in, air out.
05-15-2013, 07:15 AM | #10 |
Drives: 2012 45th Edition 2LT RS,2005 Tahoe Join Date: Mar 2012
05-15-2013, 07:17 AM | #11 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
An air intake system that helps your car breath easier will make your car more fun.
Unless you do testing of the intakes on the same car, in the same time frame, on the same dyno, with the same conditions, changing nothing on the car other than the intake, I wouldn't trust the numbers. If you use different cars, that changes the data. With the testing, the commanded AFR should be the same to determine how the unit effects the final AFR. The fuel trims shouldnt factor into the test if they are stable. They shouldnt be plus XX on one test and minus XX on another test. That makes the data not reflect the same conditions for test. Commanded timing and actual timing should remain close to the same at WOT for the test. Weather conditions should be the close to the same. IAT should be the close to the same to determine how much they rise during the run. If you pulling timing because of the IAT table on one test and none on another test, that's going to effect the final numbers. Phil |
05-15-2013, 07:32 AM | #12 |
Smoked by a GIRL
Me too. I read the question above the poll which said "do you have cold air inductions" and my brain went to the brand I have a RotoFab too.
2014 2SS/RS Summit White w/ IOM interior "Powder 2.0"
05-15-2013, 07:36 AM | #13 |
Drives: 2015 1LE Join Date: Aug 2012
05-15-2013, 03:04 PM | #14 |
Founder - Michigan FBody
Drives: 1994 Camaro LT1, 2012 Camaro 2SS/RS Join Date: Jun 2008
So in other words he has no common sense when it comes to performance modifications.
2012 Camaro 2SS/RS L99 - "Zooma"
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed "Gone But Not Forgotten" 2016 Camaro 1LT A8 - "Elmo" 2014 Camaro 1LT M6 - "Cherry Bomb" 2012 Camaro 1LS M6 - "Clifford" Michigan FBody Association http://www.mifbody.com/ |
