TireRack
Old 05-11-2013, 06:19 PM   #1
JR-Vette
JR-Vette's Avatar
Drives: 1999 500 HP Corvette
Air Inlet - Is this Normal ?
Brand new 2013 Camaro - LS3.
Is this normal where the inlet to aircleaner box just dead ends and sucks in upper engine heated air ?
Owner just bought this 2013 this week and when custom PCM tuning it I noticed IAT 20-40 degrees higher then it should be ( max about 130 deg) and then looking at air filter setup noticed as shown below
Why would it have a foam seal around the opening but just sitting open in engine bay ?
Thanks
JR-Vette is offline   Reply With Quote
Old 05-11-2013, 06:40 PM   #2
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Because SS = Stock Sucks
Time to get a haltech or rotofab!!!
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
litle88 is offline   Reply With Quote
Old 05-11-2013, 06:42 PM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I forget if it fit flush up against the front of the car. If you look through the front grill, on the right hand side, you'll see a weird piece of black plastic that directs air into the scoop. your scoop may need to be pushed down a little, depending on where the OEM scoop is.
Oh, and I agree with master Litle.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
I once parallel parked a train.
axis is offline   Reply With Quote
Old 05-11-2013, 10:44 PM   #4
SPCBA
Drives: pleather and Chiclets
looks like a bigger gap than normal but mine had a gap. the oem intake is great at sucking in heated air and muffling engine noise.
SPCBA is offline   Reply With Quote
Old 05-11-2013, 11:29 PM   #5
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
Looks just like my 2011. So your answer is yes.
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 05-12-2013, 01:06 AM   #6
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
Time for upgrade to Vararam!
Nightmare2012 is offline   Reply With Quote
Old 05-12-2013, 06:41 AM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Can't its a 2013 lol
Old 05-12-2013, 07:13 AM   #8
Denis
Denis's Avatar
Drives: 2010 SS
this!
Denis is offline   Reply With Quote
Old 05-12-2013, 10:08 AM   #9
Nightmare2012
come find out;)
2011 rad swap!!
Old 05-12-2013, 10:20 AM   #10
Alvin@PCMofNC
Drives: 2010 IOM RSS
He should really look into a CAI system. There is quite a bit of gain with a simple mod.
Alvin@PCMofNC is offline   Reply With Quote
