Vararam
Old 05-04-2013, 03:51 PM   #1
Dallas90
Dallas90's Avatar
Drives: Victory Red 2013 SS/RS Dual Mode
First Problem- If you don't count the P-zeros
I'm still doing a phone tag with Chevy over my P-zeros (covered in another thread). But this is the first problem that is sending it to the dealer, and it's one I have never seen before.
I walked up to the car and something didn't look right. As you can see, on the left front there is a non contact area right in the middle of the rotor. My best guess is that the pad is fractured or the brake pistons are frozen. The car is still in break in, so I haven't been romping on the brakes or the gas. That may explain why there is almost no pulling to the right during braking. Stopped by the dealer (it's Saturday) and they were stumped. I'll take it back in on Thursday (I'm working Mon-Wed).
I'm starting to wonder if perhaps my car was in Hurricane Sandy and they moved it to K.C., where I bought it. Just a few odd things, like the car being set up on Onstar before... very strange.
Dallas90 is offline   Reply With Quote
Old 05-04-2013, 03:59 PM   #2
Dealer didn't take the wheel and if needed the caliper of to see?
Old 05-04-2013, 04:02 PM   #3
I wonder if the pad was just warped a little. If it were pistons I'd think they'd press enough to at least keep the rust mostly off.
Old 05-04-2013, 04:05 PM   #4
Dallas90
Dallas90's Avatar
Didn't leave it, it would have just sat there until Monday anyway, then I would be out of town and it would have sat there until Thursday. I mainly wanted to see if they had any opinion, or if they reacted like they had seen this a lot. The brake- alignment guy said he had never seen it in over 20 years in the business. Did mention that some rotors were under a TSB, but it didn't look like I had those.
Old 05-04-2013, 04:06 PM   #5
Dallas90
Dallas90's Avatar
I agree with you, on the pistons. But I'm grabbing a straws here.
Old 05-05-2013, 08:18 AM   #6
christianchevell
old school chevy rodder
christianchevell's Avatar
Ricer rat cought in the brembos..........
Old 05-05-2013, 09:15 AM   #7
cmb74656
cmb74656's Avatar
Drives: 2011 Camaro 2SS/RS CGM/BLI A6
Well that's damned peculiar.
Dan Wheldon (1978-2011)
MODS: RX Performance catch can, Jegs CAI, ZL1 grille, chrome license plate frame, GM locking gas cap, Defender Worx chrome DRL bezels, GM molded splash guards, Oracle LED side markers, DRLs, tag lights and reverse lamps, Technostalgia Rapid Fire tail lamps, Vitesse shift paddle extenders, MBRP cat back.
FUTURE: long tube headers, front splitter, slotted/drilled rotors, leather console and e-brake handle boot, remote fuel door and rear seat release, sway bars and bushings.
WISH LIST: Edelbrock E-Force SC, LS3 conversion
cmb74656 is offline   Reply With Quote
Old 05-05-2013, 09:31 AM   #8
Dallas90
Dallas90's Avatar
Yep, and the rotor appears to be true. Also, doesn't pull on braking like I would think. I'm not sure how I could make this happen if I was trying.
Old 05-11-2013, 11:25 PM   #9
Dallas90
Dallas90's Avatar
Well, the rotor was defective. I took it in last Thursday, but was unable to leave it. There was hail in the forecast and they had no place to protect it. While there, we looked at them and found a very rough area that has cut a slice out of the outboard pad. That in turn has created the non-contact area.
Old 05-15-2013, 05:42 PM   #10
Dallas90
Dallas90's Avatar
Exclamation
Update, it was as last suspected. Defective rotor from the factory trashed the pad, so 1 new rotor and 4 pads to be replaced. Should get it back tomorrow. If you've got a 2013, it might be worth a look at the rotors. This damage was done inside of 1300 miles.
Old 05-15-2013, 07:15 PM   #11
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
If your onstar was already activated, your car may have been sold and returned or used as a loaner before you bought it. They can still legally sell it as a new car... you should call and see what the original in-service date is for your car. That's what they use to determine when your warranty expires and you want to make sure the clock started when you think it did.
Black 2SS ordered 1/4/2010, received 2/19/2010
clg_98ta is offline   Reply With Quote
Old 05-15-2013, 07:28 PM   #12
Dallas90
Dallas90's Avatar
Thanks, I'll do that. I'm now satisfied that it was originally delivered to this dealer and it only had 11 miles on it when I picked it up. But I will check the date.
Old 05-16-2013, 02:03 AM   #13
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
Why do you think it should pull to the right when braking? If it pulls, that's when you have something not right.
62K miles and mine has never pulled either way on braking. It should go straight unless you turn the wheel.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 05-16-2013, 08:00 AM   #14
Dallas90
Dallas90's Avatar
With part of the swept area on the outboard left obviously inop, the car should pull to the other side due to more braking on the right.
It did pull ever so slightly but that was light/normal braking, it's still in the break in period so I didn't brake hard or from high speed.
There was some confusion on the Onstar side, they had to get a higher up at the dealer to come on and give the dealer code. So Onstar is good. I really don't care about Sirius/ XM, they can turn it off any time they like.
