04-07-2013, 11:33 AM | #1 |
Track > 1/4 Mile
How much air in tires for Autocross?
About to do my first autocross next weekend, and was wondering what the ideal tire pressure (operating temp) would be for autocross. I know for the drag strip I over inflate my front and deflate my rears.
My tires are 255x20 front and 275x20 (Pilot Super Sport) rear.
04-07-2013, 01:07 PM | #2 |
SOON.........
Drives: 2010 ABM SS/RS Z-281LE Join Date: Jan 2008
No, it's not a real Z/28.....
04-07-2013, 04:31 PM | #3 |
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6 Join Date: Dec 2011
04-16-2013, 10:03 AM | #4 |
Drives: 2017 Camaro 2ss Join Date: Jul 2010
what pressures did you wind up using?
04-18-2013, 01:54 AM | #5 |
Billy The Kid
Drives: Cyber Grey 2SS/RS Join Date: Jun 2009
The one time that I went to an autoX in the camaro I checked the tires between runs just to make sure they were below 40psi. after my fastest run they were around 38 or so.
What did you end up doing...?
CGM 2SS/RS[SIZE="1"]
Performance: LT Headers/Stainless Works cat-back, 225/233 Cam, 1LE 3.91 gears, Custom Tune, BMR suspension, MGW Shifter, Stainless brake & clutch lines, Ideal G Master Cylinder, 275s on all 4 corners Aesthetics: ZL1 Spoiler, DIY LED marker lights, AACPlasma DRL, Yellow Calipers, painted factory wheels |
04-18-2013, 01:22 PM | #6 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
For us im running around 34psi front and rear anything higher and the car is very loose our next event is the 5th and i may play with running lower, but we also have quite a bit of camber in the car front and rear witch will change how the tire rolls
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
04-18-2013, 07:06 PM | #7 | |
Drives: 2010LSM6 Join Date: Feb 2011
Late to the Punch :-(
Long story short, I inflated his fronts to 40 and his rear to 35. His car was a handful for me, to say the least. My main observation between his and mine was that his car pushed in the turns while mine is neutral with the same inflation pressure. Next time (there may never be one), I would even out his inflation pressure front to back at about 36 and loosen his front sway bar to the middle hole. I expect that might neutralize his handling. Bottom line? I drove his car twice and mine eight times that day. My fast time in my car was 2.1 seconds quicker. I am much more familiar with my own car, of course, and could probably have equalized my times, but I am not sure how his could be quicker. 2.1 seconds is almost forever on a 35 second autocross course. Hence my handle, I suppose. Are you anywhere in the Midwest Region? I drive in Portage and South Bend, Indiana. Been thinking about the Chicago and Fort Wayne Regions too.
K&N Typhoon, Spohn sway bars, Pedders front radius rod bushes, BMR cradle bushing inserts, Enkei Tuning Raijins (20.7 lbs ea.), Dunlop Direzza Z1 Star Specs, -2 front camber, -1 rear.
04-18-2013, 09:15 PM | #8 | ||
Track > 1/4 Mile
Most importantly I had a blast and now I'm hooked. Much more fun than the 1/4 Here's a video of three of my runs (worst to best)
04-18-2013, 09:56 PM | #9 |
SOON.........
I run at Fort Wayne, made it to two events last year, planning on a full or close to it season this year with a trip or two over to South Bend. The points winner for F Stock last year ran a 2010 SS, he moved up to ST this year not sure if its X or U...... I'm planning on staying in Stock for at least this year. It would be great to have you at any of FWR's events, we're the only two 5th gens there and we have our hands full with a herd of Mustangs and a lone SRT Challenger.
04-18-2013, 10:28 PM | #10 | ||
After looking at your vids, I see that for a novice you take a very good line. I envy your supercharger. And, please answer, are those Ventus V12s (or something like that) for tires? If so, makes your performance even more impressive.
04-18-2013, 10:35 PM | #11 | |
04-19-2013, 01:30 AM | #12 |
Drives: '10 RJT-2LT/RS & '10 Buick LaCrosse Join Date: Jul 2009
BaylorCamaro, I run BFG Comp 2. Ran them at 38 cold. They heat up to around 40. The edge of the front tire start to cup if I run anything below 38. These tire were a bad choice. Have some friends running Nittos. Will see how they hold up.
04-19-2013, 09:34 AM | #13 | |
Track > 1/4 Mile
04-19-2013, 12:46 PM | #14 | |
SOON.........
