03-12-2013, 04:42 PM | #1 |
LongTimeLurker
Drives: 2011 SIM 2SS/RS Convertible L99 Join Date: Dec 2012
Looking for interior glass cleaning tips?
I read some good tips for cleaning the exterior, but I was not sure if this applied to the interior as well. I am not sure if there is anything I should look out for when cleaning the interior side of the glass. I am talking the windows, not things like mirrors. Just to be clear.
Also getting the entire interior windshield glass cleaned can be a pain to even reach everywhere. So even tricks or tools people found that made getting those hard to reach spots clean. My car is stock with no aftermarket tint, I was told it was owned by a non smoker but I just cant seem to get ride of the grim on the interior. I have used various glass cleaners. The best luck I have had was with invisible glass. But I am not sure if the previous owner used any glass treatments like RainX on the glass. So for mean I was looking for A to Z tips on glass cleaning. Striping it down to glass to remove any previous treatments, cleaning/polishing and then finally I would assume there is some kind of sealant/treatment at the end. |
03-12-2013, 08:28 PM | #2 |
LongTimeLurker
36 views no posts?
03-12-2013, 08:40 PM | #3 |
I like teeth.
Drives: #198 Join Date: Oct 2009
I find it very weird that glass cleaner isn't working. Normally I would never say this, but you say you have no tint. If you need something with a bit more bite, use some APC on a microfiber, spread it around on the interior of the window, clean with a different microfiber. Then use a third microfiber in conjunction with invisible glass, and a fourth microfiber to dry. That *should* do it. Repeat with APC if necessary.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517 "When you want to succeed as bad as you want to breathe, then you will be successful." |
03-12-2013, 09:09 PM | #4 |
LongTimeLurker
it seems like no matter how much I use a glass cleaner on it is has a "film" on the inside of the windshield.
I am pretty anal about cleaning cars, and everything has its own microfiber towel. So in the case of windows, I spray my blue microfiber towel with invis glass, apply it on and give it a rub. I use a orange towel to wipe off excess and then I do a final wipe down with a white towel that is usually like 99% dry. Most of my stuff is color coded. I have yellow towels that I use for waxing only. white towels are usually always for dry. I have tons of good quality microfiber towels and I have several colors of them. I buy them a few times a year when they go on sale. I like the packs that have like different 5-6 colors. Blue is anything wet, or application. Orange is after the wet or removal yellow is for waxes White is for dry ONLY Green is for plastic cleaners grey or brown is sealants only I hand wash them and rinse any towels I use and hang dry them in my tool shed. As the towels wear out I start using them for applying polishing. or dedicate them to things like rubber cleaners or wheel wells. I can always tell these cause they are clean but are usually fairly stained. I likely have a pile of like 20 or so mirofibre "rags" now that are for general purpose now, like wiping down spilled gas on my lawn mower, and just to be sure I dont use them again, i cut off a corner of the towel. Even my 10yo son knows that a "rag" to clean off is bike is a rag with a missing corner! My fear was that maybe it is some kind of anti-fog or rainx sealant on the inside and maybe a glass cleaner is not harsh enough to remove it. |
03-12-2013, 09:15 PM | #5 | |
I like teeth.
Try with the APC as I mentioned above and see if that helps
03-12-2013, 09:18 PM | #6 |
Drives: 1968 Coupe, 2010 2SS, 2011 2SS/RS Join Date: Oct 2011
Sorry, I looked but did get time to post.
Your biggest problem area is likely behind the break light in the rear window. Try wrapping a MF towel around a spatuala. I agree with Roshan, try some APC then follow up with your window cleaner on the other problem spots. It should go with out saying but make sure your using the right towels. Finally, of that doesn't work, try clay baring the window and follow up with your glass cleaner. http://www.adamspolishes.com/t-Detai...ing_Glass.aspx Good luck
03-12-2013, 09:20 PM | #7 | |
I like teeth.
I would do APC first, and then if that doesn't work, move up to clay bar.
03-12-2013, 09:27 PM | #8 |
Yep!
03-12-2013, 10:00 PM | #9 |
Drives: 2013 Camaro ZL1 Join Date: Nov 2012
I had the same trouble, I would think it was clean then once in sunlight I would see streaks. I found it was how I was washing my micro fiber towels. Once I started using a micro fiber towel wash, all my trouble went away.
03-12-2013, 10:57 PM | #10 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
For good measure, claybar the outside as well. I had streaks that wouldn't come out as well. Cleaned outside and in without getting them out. Finally clayed the outside and they magically disappeared.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
03-13-2013, 06:17 AM | #11 | ||
LongTimeLurker
When I clay the exterior paint, I will clay the windshield inside and out. Again my thoughts were someone used rainx or window sealant on the interior. Thanks guys |
03-13-2013, 12:49 PM | #12 |
Drives: The shiny ones. Join Date: Mar 2010
Two tips I'll throw out there:
03-13-2013, 12:54 PM | #13 | ||
Sorry I missed this, but I'll put money on this being the culprit! Microfibers need to be washed with non-perfumed detergent with no dyes or fabric softeners. They can also be washed with something like our Microfiber Revitalizer and Brightener. It's made to break down any cleaning materials left over in your towels after use. Here's an FAQ Dylan wrote on our forums that addresses proper MF cleaning and care: Quote:
03-13-2013, 01:51 PM | #14 | |
LongTimeLurker
Sent from my iPad using Tapatalk HD
2011 2SS/RS |
