Old 03-04-2013, 10:24 AM   #1
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
AFM...Auto/Manual...On or Off?
As I understand it, the LT1 in the Corvette will have AFM (cylinder de-activation) in the auto trans, and (new for this year) in the manual trans as well...
...Was wondering if a driver choice on/off "switch" of some type is going to be on the car that would keep engine in full V-8 mode...Thanks...
Old 03-04-2013, 10:27 AM   #2
Drives: 2023 GMC Canyon, 2020 Colorado
A few sources speculate that putting the car in certain driving modes like Track will reduce how often AFM kicks in.
2020 Chevrolet Colorado W/T Extended Cab (State-issued)
Old 03-04-2013, 12:29 PM   #3
Stingray
just can't get enough
Stingray's Avatar
Or completely disable(?) AFM in Track Mode... time will tell.
Old 03-04-2013, 01:31 PM   #4
volsfan0911
Drives: '10 GTI for now
I believe I've read somewhere that Track will completely disable AFM. CAGS remains another story? I'd expect someone will come up with a hack in relatively short order for both the skip-shift and cylinder de-activation if desired. In one of his interviews, Tadge notes that a torque converter automatic transmission played really well with AFM. Or something to that effect.
If it really is as transparent as they claim, I'm fine with the system in Eco mode or Wimp mode or whatever they want to call it. 26 average mpg doesn't like a bad deal as long as all the ponies are available IMMEDIATELY if in Sport or Track mode.
volsfan0911 is offline   Reply With Quote
Old 03-04-2013, 04:32 PM   #5
ec1990
Drives: 2012 AGM SS
CAGS may actually be disabled if Track mode if a true Track mode.
I believe it has to meet a set of parameters, RPM, speed, gear, etc... to engage. Take the gas mileage the drone won't be bad when you're at 1500 RPM's in 7th gear at 70MPH.
ec1990 is offline   Reply With Quote
Old 03-04-2013, 06:16 PM   #6
volsfan0911
shouldn't be any at all. Even on the "base" non-NPP exhaust there is a primary butterfly valve in front of the mufflers which serves to cancel out V-4 drone when the motor is running in AFM mode. We'll see how it sounds though. And honestly? I never drive that slow in my GTI on the interstate typically. Sure as hell don't see myself doing 70 in my C7 much. Either slower if I'm in traffic or there's law enforcement around or a little faster
Old 03-06-2013, 08:29 PM   #7
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Once we crack the code to the ECM, as many guys in the corvette world will want that off like the Camaro guys. It will be more interesting how its done in the manual mode.
Phil
Tampa Tuning is offline   Reply With Quote
Old 03-06-2013, 08:43 PM   #8
volsfan0911
Phil
it'll be interesting to see how long it takes the aftermarket community to break it. 5 minutes? OK, probably a little longer. But it'll happen pretty quickly I'm betting..........
Old 03-06-2013, 09:34 PM   #9
WesC5
Drives: 2004 Silver Corvette Coupe
CAGS....ugh.... Pain in the arse....especially in heavy stop and go traffic.
WesC5 is offline   Reply With Quote
Old 03-06-2013, 09:57 PM   #10
JR-Vette
JR-Vette's Avatar
Drives: 1999 500 HP Corvette
The same E92 or E95 PCM that will be used in the C7 has been used in Europe for over 2 years now and no one has been able to crack it
It is not as easy as someone ripped off GM's security seed as the E38,E40 E67 or even older 0411 PCMs
It now requires the PCM to act like a node client and pass security to a remote GM server for controller software updates and all this about how easy and how everyone is going to just start throwing mods at C7 it are in for a rude surprise.
JR-Vette is offline   Reply With Quote
Old 03-07-2013, 01:05 AM   #11
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Phil
Why would it be any different than the Camaro in manual mode?
Old 03-07-2013, 08:39 AM   #12
ec1990
Drives: 2012 AGM SS
I believe he's talking about manual transmission. LS3 doesn't have AFM/DoD, the LT1 is the first to apply it to manual transmissions.
I could see it being difficult, does it turn off during a gear switch or rev match? Does it only turn off on downshifts, not upshifts, etc...
Old 03-07-2013, 10:27 AM   #13
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Ahhh gotcha..
Old 03-08-2013, 08:38 AM   #14
volsfan0911
went and did some research - you're absolutely correct. Well, I wasn't planning on any immediate mods anyway (other than hopefully being able to defeat CAGS) so that's a good thing.
