Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > Wheels | Tires | Suspension | Brakes
Old 02-28-2013, 12:01 PM   #1
Tran
Administrator
Tran's Avatar
Drives: 2010 Camaro of course....
Post SANLUIS Rassini Rotors Chosen for C7 Chevrolet Corvette Stingray Z51 Package Brakes
Industry’s First Ductile Iron-Gray Iron Rotor Design Offers Up to 18 Percent Weight Savings, Higher Performance
PLYMOUTH, Mich., February 27, 2013
– SANLUIS Rassini, a leading automotive supplier of suspension and brake components in North America, was selected by the Chevrolet Corvette engineering team for its unique two-piece rotor design, which offers significant weight savings and extreme performance at high speeds.
Rassini’s Automotive team has produced the industry’s first-ever rotor with a ductile iron hat and gray iron brake plates for the 2014 Chevrolet Corvette Stingray, which makes its debut this summer. The unique combination of ductile and cast iron provides a weight savings of up to 18 percent while also improving the Corvette’s heat management capabilities, giving the sports car reliable and consistent stopping power.
A component of the Corvette Stingray Z51 Performance Package, the Rassini dual-cast braking system affords confident stopping power to the 6.2-liter engine that powers the Stingray from 0 – 60 mph in less than four seconds.
The rotor features an I-Beam extension design instead of a solid extension design. It is the only composite rotor on the market that can accommodate a drum in hat, a rotor design in which the internal surface of the hat serves as a brake drum.
“By optimizing both the design and the materials used in the rotor, we are able to achieve weight savings and performance improvements that were not attainable before,” said Eugenio Madero, CEO, SANLUIS Rassini North America. “This technology was developed for high-performance vehicles like the 2014 Corvette that require better heat transfer capabilities at lighter weights.”
Incorporating the I-Beam design increases air flow through the vent passage for better thermal heat transfer. The use of the stronger ductile iron in the hat allows Rassini engineers to use thinner sections of material while maintaining structural performance. The use of the center connection to the hat optimizes air flow throughout the system, dissipating heat more effectively and minimizing the stress traditionally present in a conventional full-cast design.
The manufacturing process for the rotor is contained within SANLUIS Rassini’s manufacturing facility, as it is the only supplier in the Americas industry with a fully integrated brake rotor facility. The company’s facility in Puebla, Mexico, features an integrated foundry and features machining, coating, stress relief and FNC (Ferritic Nitro-Carburizing) processes.
“We offer a unique combination of competencies in raw materials and can provide our customers with complete solutions,” said Madero.
Tran is offline
Old 02-28-2013, 04:45 PM   #2
mikeyg36
Drives: 2015 Z/28 #533
Very cool; I'm looking forward to braking tests, maybe they'll hit Z06 numbers...
mikeyg36 is offline
Old 03-20-2013, 09:20 PM   #3
OldJedi
Use the Force
OldJedi's Avatar
Drives: 2015 Corvette Z51, 2018 Porsche GTS
Send a message via AIM to OldJedi
What is interesting in the design of the rotors. Chevy/Corvette has said for years that their non-slotted/drilled brake rotors did just as well as aftermarket drilled/slotted rotors. They must have found something that they like with the new slotted design.
Walk softly, carry a light saber and drive a ZL1!
OldJedi is offline
Old 08-11-2013, 12:24 AM   #4
C6Z06dude
Drives: 2009 C63 AMG,06 Evo,07 VW GLI,
Just so that you know, the stingray C7 already busted the braking distance of the Z06. It does it below 100 ft.
09 Mercedes Benz C63 AMG
12.9@111.04 mph stock at SIR(Tucson 3100ft)
Currently 12.3@118.59 mph with tune , headers and air filters
Previous car> 08 Z06 with cams, heads,headers and other minor stuff
C6Z06dude is offline
Old 08-11-2013, 12:25 AM   #5
C6Z06dude
This article contradicts the article on this forum in which they show that the rotors are made by Brembo. This is what I am talking about:
http://www.corvette7.com/forums/showthread.php?t=311450
Old 08-11-2013, 04:46 AM   #6
Hancock
Drives: Blk Z51 NPP J6F Q7T Red Interior
That supply diagram is for the base car. The Rassini rotors are on the Z51 package.
Hancock is offline
