#1 |
Administrator
Photos of C7 Corvette Stingray tail lights in action, parking assist, and HUD
Photos courtesy of Dave@Kerbeck, showing the C7 tail lights in operation at night, the parking assist screen, and HUD.
#2 |
just can't get enough
Sweet! The last pic made me feel all :hippie:
Reverse (white ones lit) lamps are only the 2 inboard ones? What are the outers for? ![]() |
#3 |
![]() Join Date: Jan 2013
hope its easy to swap a bulb if my taillights go out!
#4 |
![]() Drives: 2010 Camaro 2SS RJT Join Date: Feb 2009
#5 |
Slammin' all six gears
Drives: 1991 Z-07 Corvette 2006 YZF-R6 Join Date: Jan 2013
Notice the butterflies in the exhaust?
#6 |
![]() Drives: 1987 Corvette TPI Join Date: Mar 2012
I sure did notice the butterflies
#7 |
![]() Drives: 2012 triple black ZL-1 #799 Join Date: Jun 2012
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS/RS M6/2500HD Lmm LTZ Join Date: Apr 2012
She so sexy.........:usa:
#9 |
:rockon:
#10 |
![]() Join Date: Feb 2013
I am a real amber rear turn signal geek. I went so far as putting 'Euro' lights in my 2001 coupe less than 2 weeks after bringing it home from Museum delivery. Wifey was a bit dismayed when she came into the garage to find:
![]() It all worked: ![]() It sure makes more sense to me than combined turn and brake lights. I'm always irritated to see Saturns and Malibus with amber turns and my Corvette didn't even have separate turn lights. It seemed to me that the ambers were safer and, sure enough, a while back I found this: ------------------------------------------------------------ The Effectiveness of Amber Rear Turn Signals for Reducing Rear Impacts DOT HS 811 115 This purpose of this report is to determine the effect of rear turn signal color on the likelihood of being involved in a rear-end crash. Federal Motor Vehicle Safety Standard No. 108 allows rear turn signals to be either red or amber in color. The principal finding of the report is that amber signals show a 5.3% effectiveness in reducing involvement in two-vehicle crashes where a lead vehicle is rear-struck in the act of turning left, turning right, merging into traffic, changing lanes, or entering/leaving a parking space. The advantage of amber rear turn signals is shown to be statistically significant. ---------------------------------------------------------------- Okay, the C7 - I found this at Corvette Action Center as part of a interview by Jake Drennon (C5 Registry) with Kirk Bennion (Corvette Exterior Designer). Kirk: "The 2014 Corvette tail lamps are actually global-compliant, so we don’t have to put another tail lamp on the car. For Europe, you’ll have one backup and one fog light – it comes out of the same quadrant, and the park and turn stay the same, but the inner are changed out. So, in Europe, for the people that don’t use the fog lights, the lamp look is the same between domestic and global." These tail lamps also have amber LEDs. Amber LEDs are the most expensive. So typically, a lot of cars won’t use amber LEDs for that reason, but here again, in keeping with wanting to raise the bar, that was something we told Tadge was a have-to-have." Fortunately, I found this thread with this new-to-me picture: Finally, for the two or three people who care about this and have stuck with me this far, here is my conclusion: Kirk talks about 'quadrants' because, I think, the tail light on each side has four different sections: - Outboard unit with a 3D u-shaped lens surrounding a flat lens - Inboard unit also with a 3D u-shaped lens surrounding a flat lens And here is my take on what Kirk was saying (are you still following?) - Domestic - Outboard 3D lens - Diffused red LEDs, two stage: - Standard Brightness, Park (and running) Lights - Brightest, Brake Lights Outboard flat lens - Amber LEDs (YES!!!): - Turn Signals Inboard 3D lens - Diffused red LEDs, two stage: - Standard Brightness, Park (and running) Lights - Brightest, Brake Lights Inboard flat lens - White LEDs: - Backup Lights Export - in Countries Requiring Switchable Bright Red Rear Fog Lights - Same as Domestic Except: Inboard flat lens - White LED (one side only - drivers?): - Backup Light Inboard flat lens - Red LED (other side): - Switchable Rear Red Fog Light Export - in Countries NOT Requiring Switchable Bright Red Rear Fog Lights - Same as Domestic ------------------------------------------------------- What do you think? Did I get it right? Does anyone have actual facts?
David
#11 |
![]() ![]() ![]() ![]() Drives: 2012 AGM SS Join Date: Jun 2012
Seems pretty plausible and what most likely will happen. The only thing I could see happening if we see a video of the turn signals working is a dual colored bulb where the inboard lenses could double as a reverse light and turn signal.
I do wish most cars came with much brighter reverse lights, putting 5-10% tint makes backing up pretty annoying, although greatly helped by a reverse camera. |
#12 | |
David
#13 |
Tampa Gulf Coast Family
Love those taillights!
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Z/28 #533 Join Date: Jul 2012
I like the new HUD design
Thread Tools | |
