#1 |
*new car smell*
Drives: 2007 Ford Mustang 'Natasha' Join Date: Jan 2007
I was gonna go out and run down to the Kwik Fill for some hot chocolate and I got in my car started it up and was about to brush off the snow on my windows (not much as the snow on left door fell off when I closed it) and I saw that my auto lights (that turn on when the key is turned to ON) only had the park lights, dash lights and tails. I thought I was seeing things then the lights came on for a few seconds then shut back off again. I got in the car and shut it off and turned the switch on and off and got everything BUT the headlights. I work nights so I dunno how I can drive my car till I find out what is causing this. It has NEVER happened to me before.
"May the forces of evil become confused on the way to your house."
George Carlin |
#2 |
CamaroFans.com
So this is on your Monte Carlo? Check the connection at the headlamps.
#3 |
*new car smell*
yeah it is the Monte, the only car I have I cannot really check them in the dark I will in the morning.
George Carlin |
#4 |
CamaroFans.com
I'm not sure how that wiring harness works but if both lights are out together it may be something else. The fact that they came back on intermittently says it's probably not a fuse but something in the wiring or maybe in the dash switch itself.
#5 |
*new car smell*
well I have automatic lights so 90% of the time I never even USE that switch other than the times I want em on during day time like rain or snowy weather for other cars to see me.
George Carlin |
#6 |
*new car smell*
UPDATE, I do have high beams, but strangely I have no DRL lights cause what is strange is the DRL on my car ARE the high beams at low power.
George Carlin |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '86 Monte Carlo SS Join Date: Nov 2010
from this forum..
http://montecarloforum.com/forum/gen...lutions-30154/ Problem: My headlights don’t work or my high beams won’t stay on Like cause: Bad multifunction switch (MFS) Temporary solution: Jiggle the MFS and you should be able to get the lights to work again. I stress that this is a temporary solution and should only be used to get the lights back on to drive somewhere to get it fixed. Permanent solution: Replace the MFS (I advise against junkyard replacements for this repair). Prevention: nothing |
#8 |
*new car smell*
funny when I turn on the HIGH beams they do stay on till I click it again, I will try turning them back and forth. dumb question I take it he MFS is the turn signal stalk with the wiper controls correct?
George Carlin |
#9 |
*new car smell*
UPDATE I tried turning the high and lows off no luck. as I was pulling into my life local auto parts store I saw the reflection of my DRL put the car in park they shut off tried the lights via the switch and they worked. I will get a new switch soon it was $243 at the parts store.
George Carlin |
#10 |
Drives: car Join Date: May 2008
Well if it it was a '98/'99 I've become an expert on those. But looks like '04 is different.
I did find this video for an Impala but should be the same. The problem is no high beams but still may be helpful. |
#11 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GM Vehicles Join Date: Jun 2010
I would definitely take it to a dealership to see if they can pinpoint the issue for you. Please let us know if you find out anything. Brandon Chevrolet Customer Service
For information on the GM Privacy Statement, please visit http://www.gm.com/privacy-statement.html
