09-10-2012, 02:43 AM | #1 |
Anyone done a oil cooler delete on L99?
Hi, just wondered if anyone done a oil cooler delete on the L99? I understand you use 12577903 oil cooler block off plate & 12553210 gasket then block off water pipes to cooler. Only reason why I'm asking is that mine is leaking & I live in New Zealand so have no warranty on vehicle & these things cost roun $750 to replace & looks like replacing o'rings & gaskets doesn't work all the time. What Ive read these coolers don't do a lot anyway. Any thoughts appreciated.
09-10-2012, 03:53 PM | #2 |
Sarcasm loading --------
you could buy an adapter, and run a standard aftermarket oil cooler. 750 sounds awfully steep for a factory intercooler. sounds like price gouging from your dealer / importer.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
09-11-2012, 04:36 AM | #3 |
Sounds like an idea, I'll have a look around for an adapter to suit L99/LS3 block to aftermarket cooler. cheers
09-11-2012, 10:01 PM | #4 |
Mad Ninja Skills
Would not recommend just blocking it off. LPE has an adapter kit to use a standard fluid cooler http://www.lingenfelter.com/mm5/merchant.mvc?Screen=PROD&Product_Code=L300025297&C ategory_Code=C186&Store_Code=LPE
2011 Camaro SS/RS M6 - 633whp/679tq Gave to the wife
Custom stainless 2" primary headers / Custom stainless 3" header back exhaust / Hurst short shifter / ZEX nitrous kit / Vararam intake / Spohn chrome moly trailing arms / Sin City Performance Tune / SCP custom ground cam / SCP ported & polished heads New Car 2007 Corvette Z06 - Headers / Vararam / Magnaflow Catback / SCP Tune / Nitrous / BTR Stg IV Cam and Springs |
09-11-2012, 10:23 PM | #5 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
I wouldn't delete it either but maybe a "better" more "efficient" cooler?
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
09-11-2012, 10:29 PM | #6 |
Mine's blocked off. Tens of thousands of LS engines dont have them, and the factory one sucks. Unless your road racing, I wouldn't bother with one at all.
09-11-2012, 10:31 PM | #7 |
Mad Ninja Skills
You will still need to modify a couple things.
1. You cap off the coolant fitting to the block (Blue Circle) and replace the factory t (Red Circle) in the upper rad hose with a straight connector. or 2. You add a 90* hose fitting @ Blue Circle and adapt it to factory coolant hose @ Yellow Circle I would probably recommend option 1 as it seems to be a little more simple and I don't know if you would have any clearance issues with option 2. Hope this helps and I didn't make it more confusing.
09-12-2012, 12:09 AM | #8 |
Hey thanks guy's for the info, think I may go with MaxKamai's & ipouncer72's idea & block plug block & put straight connector in, I have blank plate & gasket coming, just have to find out what size bung (15) for the block I am going to need & dia of connector pipe I will need. The less clutter the better for me.
09-12-2012, 10:16 AM | #9 | |
http://texas-speed.com/p-233-gm-large-coolant-plug.aspx The block plug |
09-12-2012, 07:35 PM | #10 | |
cheers
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
09-12-2012, 07:39 PM | #11 | |
09-12-2012, 08:23 PM | #12 |
You can order it from any gm dealer. The part # is listed on their website.
09-12-2012, 09:24 PM | #13 |
Drives: 2009 ZR1 Join Date: May 2010
I deleted mine on my LS3. I do have to thank pouncer72 as the inspiration for it. So far, no problems in the 90+ degree heat but I haven't been running the car hard either.
02-15-2013, 12:42 PM | #14 |
Airborne Pathfinder
Drives: Camaro ZL575 Join Date: Nov 2009
I just came from my dealer doing an oil change and I talked to one of the techs and I ordered the three parts and they will do the delete next week for me once the parts arrive. I believe around 25 dollars for the parts.
2010 Camaro Indy 500 Pace car, LS3-ZL575
Other cars are- 95 BMW 325 sedan- AA exhaust, AA CAI, AA Strut bar, AA chip, M3 rotors and calipers, racing clutch, oversized injectors, upgraded M3 interior- Audi A4 SLine, with black out optics |
