TireRack
Old 05-17-2009, 10:10 PM   #1
Z_Rocks
Z_Rocks's Avatar
Drives: everyone crazy...
Better engine mounts
Someone needs to come out with a better and stronger engine mounts (perhaps a bit shorter too) for this car. The stock ones are too rubbery.
Z_Rocks is offline   Reply With Quote
Old 05-18-2009, 11:32 AM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I'm sorry if this sounds rude, but have you driven this car or have one? I ask because GM makes them like they are so you don't feel the engine shake the car. That may be fine for an enthusiast, but there are a lot more critics than people like us. Sure, that thing jerks all over the place when it's making ~150 more RWHP but if they were poly' mounts, I'm sure there would be lots' more complaints than praises out there. Personally, I think I'd be one of those complaining. I'm not suggesting that that's not wasted power or anything, but unless I were intending on making a racecar (which I'm not) I wouldn't like to have to live with that. I can see your point but there's gotta' be some give and take.
'20 ZL1 Black "Fury"
Old 05-18-2009, 11:51 AM   #3
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
someone WILL make poly and solid motor mounts for this car. just wait.
do you have your car yet? or are you just basing your statements off the Hennessey vid?
I piss excellence
and fart awesomeness
Old 05-18-2009, 11:55 AM   #4
Z_Rocks
Z_Rocks's Avatar
Hi;
I should have really specified for those who will be adding F/I to this car, will eventually need a more solid EM to prevent the engine move so much. I agree that for most the current EM is perfect, but once you step up, you'll need one.
[Update], I think there may not be even necessary to go fully solid, but a bit shorter (like 1/4 inch) to minimize the rocking. You see this problem with PD S/C or Turbo, when the TQ is not so linear like Centri S/C. I've had my share of breaking soft EM before when the Turbo kicked in hard.
Old 05-18-2009, 11:59 AM   #5
Z_Rocks
Z_Rocks's Avatar
When I saw the video, it reminded me of my own previous experience of adding Turbo to a car that was not designed to hold an extra 150 lb of TQ, which I had to go with Solid EM. However, Solid EM adds other unwanted issues but at least holds the engine down from rocking.
Old 05-18-2009, 12:08 PM   #6
CamaroSpike23
Truth Enforcer
ive driven cars with solid motor mounts and as long as the motor is tuned and running properly, there isnt much more vibration over a poly mount.
I'd say give it another month or two and I'm sure some poly mounts will be out. and I dont know for sure, but poly mounts for other LS style engines should/would probably swap over
I piss excellence
Old 05-18-2009, 01:56 PM   #7
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
you should look at the magnetic variable engine mounts, they use them in the cars with magnetic rear suspension like the ZR1, CTS-V and the ferrari 599 gtb. goes hard or soft depending on the performance mode your car is in.
headpunter is offline   Reply With Quote
Old 05-18-2009, 01:58 PM   #8
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Are you cereal or just messin' around?... If you are - I had no idea...
Old 05-18-2009, 02:06 PM   #9
Z_Rocks
Z_Rocks's Avatar
Ah Great idea. But I think they are really expensive (as I recall for Z06 as an option) it was expensive. And secondly, I think the ECU needs to be programmed for that. But normally you use those for course racing, rather than street driving.
Old 05-18-2009, 02:18 PM   #10
Vash
Drives: 00 Blazer
Hum. I bet they are fine. When someone can break a mount then worry about it.
With todays engineering it would take a more detailed study them.
If Lingenfelter needs to boost them or if they use stock that would be a good sign of what the right engineering would be.
Vash is offline   Reply With Quote
Old 05-18-2009, 10:20 PM   #11
PoleCat2SSRS2010
R6P Marketing Lab Rat
PoleCat2SSRS2010's Avatar
Drives: sometimes
I am with Spike on this one.
Give the aftermarket time to get in production after they do the needed research. There will be more choices than can be imagined. I for one had solid mounts custom made b/c no one in the aftermarket would. The same mounts for a Boss 429 except solid plate. With the big motor and big cam the car was still in good manners on the street.....except for the dual 4 inch exaust dumps.
PoleCat2SSRS2010 is offline   Reply With Quote
BMEP-Or why you only need 1 camshaft rayhawk Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 12-03-2008 12:28 AM
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue 13F20 5th Gen Camaro SS LS LT General Discussions 15 09-22-2008 04:35 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
GM moves closer to HCCI engine production Scotsman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-16-2008 06:16 PM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 04:00 PM
