01-29-2012, 12:44 AM | #1 |
Drives: 2010 Camaro SS/RS Join Date: Jan 2009
20x9 on the front?
Hey, I'm about to pull the trigger on some rims, and I just want to make sure before I do. I'm not an expert so..... I can put 20x9 rims on the front (they don't make the 20x8 for the ones i'm getting) with no problems right?
Also, I want the Toyo Proxes 4 tires. Anybody had them a while? They last significantly longer than the Pirellis? |
01-29-2012, 10:04 AM | #2 |
There are many 20x9 wheels that will fit on the front.....and there are many that won't!!! It depends on the offset/backspacing, and mounting pad height. If you give us more information about the wheels, we might be able to help you a little more.
01-29-2012, 10:16 AM | #3 |
Drives: '20 Corvette Stingray Join Date: Jul 2009
this is very true.....I'm running the 9's all the way arouind with 275/40's.....I'm running the STOCK Factory wheels.....and they fit GREAT. With the factory 9's (REARS) the offset is a +40....and although there is no rubbing, lock to lock, with the 275's, the clearance is fairly close to the spring pearchs. There is about 1/4 to 3/8 of an inch clearance. So if you get a wheel with MORE offset.....ya need to be real careful.
01-29-2012, 10:26 AM | #4 | |
01-29-2012, 10:55 AM | #5 |
CRAP......I shouldn't be trying to help this early in tghe morning before I have my COFFEE!!! LOL FIXED IT!!
01-29-2012, 11:06 AM | #6 |
Isn't it that the smaller the offset the more the wheels is pushed out , and the bigger the offset the wheels is more into the car center ?Dragoneye [ POSTED BY YOURSELF ]has a explanation that seems to clear this issue
01-29-2012, 11:18 AM | #7 | |
http://www.camaro5.com/forums/showthread.php?t=111604 you need to remember there is both + AND - numbers or offsets. and I apoplgize.....you are CORRECT......I should be trying to think this hard this early in the morning!! lol I went and corrected my post.....thanks for bringing that to my attention.......its all about working togeather.
01-29-2012, 11:44 AM | #8 |
No problem man , that's my stubbornness at it's best . On the other hand you were the one that explain to me some time ago how that works , elephant memory never let it go .
02-01-2012, 01:58 PM | #9 | |
Drives: Camaro SS Join Date: Mar 2011
If you go with the Proxes 4 you will absolutely love them. We just finished doing some testing with them on our own Camaro and they absolutley great. Great hook, very quiet, and great in the rain. |
02-01-2012, 02:16 PM | #10 | |
Similar Threads | ||||
ZL1 / CTS-V Brakes | JusticePete | Suspension / Brakes / Chassis | 584 | 10-14-2021 09:33 AM |
Just ordered a Camaro, now I wait... | Slim_ | Sverige | 23 | 05-04-2012 01:01 AM |
Whiteline 10+ Chevrolet Camaro Front Heavy Duty Adjustable 27mm Swaybar Fits Models L | Xplosive Performance | Suspension / Chassis / Brakes | 14 | 12-18-2011 10:21 AM |
NO MORE FRONT PLATE! SUPPORT NYS Bill A09426 | LT1Jeep | USA - NY / NJ / PA | 17 | 05-04-2010 09:23 PM |
APR Performance CF Front Wind Splitter w/Rods | IN STOCK + FREE S&H!! | AJ@ECSMotorsports | Exterior Parts & Accessories | 4 | 05-03-2010 03:32 PM |
