dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 11-25-2011, 06:20 PM   #1
bigredbusa
bigredbusa's Avatar
Drives: 2010 Camaro, 69 Camaro
Am I wrong?
I just did my oil change and put in 6 qts, but I didn't get 6 qts out. Should i be getting 6 out? I did the change to Royal Purple and noticed a little more than 1 mpg increase but was a little concerned with not getting out 6 qts or a little less than that?
2LT/RS BLACK w/IOM STRIPES M6
Ordered 5/25/09~ Arrived 10/28/09
Named The Sexy Beast!
bigredbusa is offline   Reply With Quote
Old 11-25-2011, 06:22 PM   #2
jlauber588
jlauber588's Avatar
Drives: 2010 camaro
If you have a v6 I get the same thing. After reading the catch can forums it makes sense why that happens.
Sent from my DROID BIONIC using Tapatalk
jlauber588 is offline   Reply With Quote
Old 11-25-2011, 06:32 PM   #3
bigredbusa
bigredbusa's Avatar
I do have a V6. I gues my question is how much oil should I expect to loose if I don't have a catch can?
Old 11-25-2011, 09:41 PM   #4
jlauber588
jlauber588's Avatar
Drives: 2010 camaro
Well im loosing about 1/8 th of a quart or so every 7000. How much do u loose?
Old 11-25-2011, 10:23 PM   #5
bigredbusa
bigredbusa's Avatar
I had 3 qts in the pan
Old 11-25-2011, 10:26 PM   #6
Crime2
Got Boost?
Crime2's Avatar
Drives: 2010 1SS RS
Did you have the car level when draining? 3 seems to be to little.
Crime2 is offline   Reply With Quote
Old 11-25-2011, 10:45 PM   #7
The Stig
knows 2 facts about ducks
The Stig's Avatar
That has to be it. Three quarts is not enough to get a full oil change.
Click to view my build thread
Old 11-26-2011, 01:00 PM   #8
bigredbusa
bigredbusa's Avatar
But it took 6 to refill it.
Old 11-26-2011, 01:05 PM   #9
cowboy1948
cowboy1948's Avatar
Drives: 10 LT2/RS-08 SILVERADO-05 COBALT
Question
that is something i do not like about the oil pan drain. instead of being at the rear of the pan, so you can use ramps to roll up on. and all oil will drain.
it s on the side where you have to have the car level to get it all out. bad design for the oil drain plug i say
Retired
cowboy1948 is offline   Reply With Quote
Old 11-26-2011, 03:24 PM   #10
Bo Tie 1
Bo Tie 1's Avatar
Drives: 11 Camaro SS,05 Vette Z51,76 Camaro
Did you check the level before you drained it? Maybe it was low.
Bo Tie 1 is offline   Reply With Quote
Old 11-26-2011, 06:00 PM   #11
The Stig
The Stig's Avatar
Ah I missed that. You might have just been really low
Old 11-26-2011, 06:05 PM   #12
fielderLS3
fielderLS3's Avatar
Sounds like you may have been 3 quarts low. Check it more often. You're lucky the whole thing didn't blow up.
. 2022 1SS 1LE (Coming Soon)
Old 11-27-2011, 05:10 PM   #13
bigredbusa
bigredbusa's Avatar
ok, But how could it be low? I don't have a leak.
Old 11-27-2011, 06:01 PM   #14
jlauber588
jlauber588's Avatar
Drives: 2010 camaro
Could b a faulty seal out if the factory, it may be burning the oil. Better watch it.
Did something wrong and doing something wrong. Pfadt sway and BC coilover over instal Rogan Suspension / Brakes / Chassis 13 09-11-2011 07:00 PM
what is REALLY wrong with women Sir Nuke Off-topic Discussions 43 02-09-2010 09:41 PM
Is this wrong? and New era? MikeL 5th Gen Camaro SS LS LT General Discussions 12 02-06-2010 06:59 PM
