11-08-2011, 08:15 PM | #1 |
Drives: '16 2SS Join Date: Apr 2011
ABL Light Pipes
As the original source for these has recently dried up, we have found a second source for a very similar product.
We also have a flexible version that can be used for other applications. The minimum bend radius is about 1.5" Continuous can be free-cut and works well for shorter lengths. Tuned is for longer lengths and has a special pattern to minimize dimming in the middle. These can be cut, but, equal amounts should be taken from each end. Expanded can be free-cut and is for flex applications where there are multiple bends which would make alignment difficult. Sized for no-drill ABL mod (LED's under panel, not behind dash). Note that 2013+ cars require three holes to be drilled into the dash to pass the LED's through. Complete Dash Kit - from $71 http://sjmautoprod.com/5th-gen-Camaro-Dash-ABL-Kit.html Dash Pipe Package - $25 Driver-Side (Continuous, Flex) and Passenger-Side (Tuned, Rigid). http://sjmautoprod.com/5th-gen-camar...-pipe-kit.html Driver Side Flex - $9 For those who have rigid pipes and are not happy with the panel fitment. http://sjmautoprod.com/light-pipes-5mm.html Door Panels - Per Door Top of Panel: Flex, Tuned: $17 (2LT/SS stock setup) http://sjmautoprod.com/Interior/5th-...Pipes-Top.html Bottom of Panel: Flex, Tuned: $20 (order both for full-panel lighting)* * Requires custom door panel http://sjmautoprod.com/Interior/5th-...es-Bottom.html Wiring Dash Harness T-Tap/Solder: $23 Plug-n-Play: $48 - ZL1 version available upon request http://sjmautoprod.com/5th-gen-camar...n-harness.html Standard Color LED's: $12 ea. http://sjmautoprod.com/5th-Gen-Camar...o-ABL-LED.html Splitter: $13 ea. 3-Way Splitter (for full door panels): $18 ea. Pipes For Customizing (all free-cut) Rigid, Continuous, 39.4" [1000mm]: $12.92 Rigid, Expanded, 39.4" [1000mm]: $14.25 Flex, Expanded, 39.4" [1000mm]: $20 Flex, Expanded, 78.7" [2000mm]: $28.52 Custom lengths can also be provided. http://sjmautoprod.com/Light-Pipes-5mm.html Prices do not include shipping. Last edited by sjmautoprod; 02-27-2018 at 06:14 PM. Reason: Added links |
11-09-2011, 12:13 AM | #2 |
www.Camaro5store.com
I already have mind done. BUT...I'd LOVE to see one of these in person!
Will you be selling the light pipes with LED's included? ...that match GM's lights? Or, is it just the light tubes. BTW, these look MUCH brighter than the GM ones. Is that how they are or is that the LED that makes it look that way??? Last question. Does the back have a ridge which amplifies the light?....like the original Tyco light pipe? |
11-09-2011, 06:01 AM | #3 |
knows 2 facts about ducks
Drives: ...and they're both wrong Join Date: Aug 2009
11-09-2011, 07:04 AM | #4 |
This is just for the pipe, but, we can get LED's, too.
Not sure how these compare to the originals. There is a feature on the back for directing the light. |
11-09-2011, 07:22 AM | #5 |
Drives: 1997 30th Ann. Z28 & 2010 2LT RS Join Date: Jan 2010
11-09-2011, 07:46 AM | #6 | |
Hopefully....it'll have this. If it does, you are 100% on the right track for ABL to be done the right way! |
11-09-2011, 08:12 AM | #7 |
I have a piece of tyco light pipe in my glove box. I can take a picture to show you what Tag is talking about.
11-09-2011, 08:29 AM | #8 |
Go ahead and post it. Let's see if that's going to be the same light pipe.
I talked with Brandon Kasprowicz from Digi Key over the last couple days trying to find if they could get the light pipe. He said that it would basically have to be a VERY large order for them to place the order with TC Communications. I wonder if they could even order them....probably not. |
11-09-2011, 09:33 AM | #9 |
Thanks, but, we have seen the TE light pipe, just not when they were powered.
As I said, these do have a feature for directing the light. |
11-09-2011, 03:02 PM | #10 |
Here you go.
11-09-2011, 03:43 PM | #11 |
Yessir, that's it. I'll shoot a similar video later tonight with our pipe.
11-09-2011, 05:06 PM | #12 |
Can I put my name down for the pre order? I figure I'm going to need like 8 feet.
11-09-2011, 06:43 PM | #13 |
11-09-2011, 07:12 PM | #14 |
I just have some ideas. You said yours is flexible, can you post a video of you bending it?
Similar Threads | ||||
Who is up for an install day for the dash ABL? (Updated) | 2010SSRSM6 | USA - California | 565 | 07-10-2012 08:41 PM |
Jba catted mud pipes....check engine light on? | Camarowguy | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 13 | 07-23-2011 08:35 AM |
WTB: ABL Light Pipe 2058296-1 Tyco | irocnroll | Interior Parts & Accessories | 13 | 05-20-2011 08:20 PM |
Those with LT's, RESET your check engine light! | TAG UR IT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 107 | 08-18-2010 01:51 AM |
ABL lighting and Footwell Light Install? | JProberts | USA - Mid-Atlantic | 3 | 02-25-2010 10:17 PM |
