Old 09-12-2011, 07:13 PM   #1
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
Weight reduction list...
Since I was harassed to type it out in the other forum , here you go. Additional numbers courtesy of BMR
-6 Airbags (Side Curtain, Seats, dash) (-13.4 pounds)
Dash removed, lightened, tubular steel loop cut off of cross brace, cross brace lightened, sound deadening removed from backside of FW (-30 lbs)
Removed rear seats, belts and brackets, and sheet metal holding bracket mounts (-45.4 pounds)
Weld RT-S & tires vs stock 20s (-85 pounds)
Headers/X/Dumps at axle for weight (-60 pounds)
Tubular front crash support (-12 pounds)
Remove rear crash support (-26 pounds)
!Evap (9.7 pounds, not including evap line, which I left in)
!A/C (-49 pounds)
!Wiper Motor Assy (-9 pounds)
!Junk Block Oil Cooler/Heater, unnecessary (-7 pounds)
Lightweight Billet clutch vs. stock (-12 pounds)
Sound deadening removed from under seats, backseats, trunk, including hood/trunk liner (-8 pounds)
Braille battery (-29 pounds)
Windshield Washer Tank + Pump and lines empty weight (4 pounds)
ITEM
WEIGHT (LBS.)
LOWER REAR SEAT
10.2
UPPER REAR SEAT
28
DRIVERS SEAT
54.6
PASSENGER SEAT
44
A/C EVAPORATOR CORE ASSY.
13.4
A/C COMPRESSOR
13.2
A/C CONDENSER
6.4
A/C-HEAT BLOWER MOTOR ASSY
4.2
A/C LINES AND DUCTING
7.6
A/C FIREWALL COVER
3.6
DRIVERS AIR BAG
1.6
PASSENGER AIR BAG
5.4
SIDE AIR BAG (EACH)
3.2
FIREWALL INSULATION
2.8
FLOOR INSULATION
12
TRUNK CARPET AND WELL COVER
15.2
TRUNK COMPRESSOR
6
TRUNK-LID STRUTS (PAIR)
1
FRONT BUMPER
14.6
REAR BUMPER
26.4
RADIO
4
DOOR SPEAKERS (PAIR)
3.6
FLOOR MATS (FRONT PAIR)
4.8
CENTER CONSOLE
8.2
EMERGENCY BRAKE LEVER W/CABLES
6.2
FRONT SEAT BELTS (PAIR)
6
REAR SEAT BELTS (PAIR)
3.6
FRONT BRAKE ROTORS (EACH)
25.4
REAR BRAKE ROTORS (EACH)
24
FRONT CALIPERS (EACH)
11.4
REAR CALIPERS (EACH)
7.4
HOOD
25.3
HOOD INSULATION
1.2
HORNS (PAIR)
1.4
WIPER ASSEMBLY W/MOTOR
8.6
WINDSHIELD COWL PLASTIC
3.6
DRIVESHAFT – 6 SPEED MANUAL
24
FUEL TANK SHIELD
2.8
DRIVE SHAFT HEAT SHIELD
.8
STOCK AIR BOX
7
ENGINE COVER
4.4
CLUTCH ASSEMBLY (INCLUDING FLYWHEEL)
57
DietCoke is offline   Reply With Quote
Old 09-12-2011, 07:16 PM   #2
jasycz28
J.Sick
jasycz28's Avatar
Drives: 2010 Camaro SS
PICS???
"J.Sick"
2010 Camaro 2SS
jasycz28 is offline   Reply With Quote
Old 09-12-2011, 07:18 PM   #3
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
No pics of the interior work other then right after I pulled the dash, I didnt take any when I did it. The supports are hiding behind the bumpers, and the dash stuff isn't visible. But yeah, other then brakes/coils I've got a few ideas to get the car to 3500 lbs. It's VERY close. Lexan back glass will drop another 40, and contemplating getting a sheet metal drivers seat to swap in for race days for another 30.
Old 09-12-2011, 08:01 PM   #4
Squintz Palladoris
Squintz Palladoris's Avatar
Drives: 2010 IOM 1SS M6
Thanks for this Diet. Mods should make this a Sticky
Squintz Palladoris is offline   Reply With Quote
Old 09-12-2011, 08:04 PM   #5
Supercharged SS
Drives: 2010 Camaro
I'd love to loose 400 lbs from my car. That would do the trick!!
Supercharged SS is offline   Reply With Quote
Old 09-12-2011, 08:37 PM   #6
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
Let PQ drive it...
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 09-12-2011, 08:58 PM   #7
Supercharged SS
Drives: 2010 Camaro
Originally Posted by SSE 4 2SS View Post
Let PQ drive it...
So you're saying I have a weight problem:( On chemo I'm only 150, down from 175 so I guess you can say that I am reducing weight. I picked up .025 just from that!!!!!!!!!! That brings the car with me and 4 Bogarts to 4170#. 3500 would be sweet!
Old 09-12-2011, 09:06 PM   #8
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
Let PQ drive it...
HufferSS is offline   Reply With Quote
Old 09-12-2011, 10:14 PM   #9
usa1camaro1969
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
I thought he was sayin' PQ would lop a 670lb chunk of your car off...
I wake up in the morning and I piss excellence.
-Ricky Bobby
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
usa1camaro1969 is offline   Reply With Quote
Old 09-12-2011, 10:20 PM   #10
Black5thgen
Drives: 2007 C6
Are the tubular crash supports available to buy or were they fabricated?
Black5thgen is offline   Reply With Quote
Old 09-12-2011, 11:42 PM   #11
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
They were fabbed from 1 1/8" OD chromoly and some basic 3/16" plate (leftover roll cage tubing). Nothing fancy, just functional. Surprised no one offers a manufactured piece, but it's also a liability for a MFR as technically you are modifying the car's crash structure, even if you're making a stronger and lighter part.
I did add a few pounds back to the car with the rear drag bar (necessary) and the DSS/Hendrix axles (also necessary). A 6 point is going to add another 40-45 pounds, which is unfortunate, but I'll find that weight elsewhere.
Old 09-13-2011, 12:03 AM   #12
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
This,^^^ wheels, bumpers, oil pan.... etc... lol,,, It just struck me...
Jaime, I'm sure with a little bit of cooler weather, you'll be in the nines, without any further weight loss...
I hope everything is headed your way in re the Chemo... My brother in law just went through a long term battle... That was a roller coaster I don't wish on anyone...
Old 09-13-2011, 12:09 AM   #13
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Didnt put engine cover, intake cover, or tire inflator/foam on the list, but I didnt weigh those either. Maybe another 6-7 pounds there.
Front swaybar I'm still up in the air about. May keep it may ditch it, depends on how the car behaves with the drag bar in the back.
Old 09-13-2011, 08:18 AM   #14
Squintz Palladoris
If you are runnin around on Skinnies I dot think you will run into a problem with oversteer
Wide tires up front different story.
Official 1/8 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 763 08-12-2022 04:51 PM
Cost-Effective Camaro Weight Reduction CamaroFemme 5th Gen Camaro SS LS LT General Discussions 34 12-21-2010 10:52 PM
weight reduction options 2K05GT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 24 12-18-2010 08:05 AM
weight loss CamaroSpike23 Off-topic Discussions 8 09-17-2009 07:16 PM
Camaro Weight JeepinMatt 5th Gen Camaro SS LS LT General Discussions 62 03-26-2008 09:17 AM
