Old 08-08-2011, 02:47 PM   #1
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Disable and delete the annoying vert top clearance net.
8/8/11 This has annoyed me more often than I can count. I am cleaning my car or out driving around and I want to put my top down. I pull off to the side of the road, unlatch the top and nothing happens. The damn safety net thing isn't pulled out! I have to get out of the car pop, the trunk, oh wait, the trunk won't pop unless I latch the top back up! I latch the top, pop the trunk, get out of the car, walk to the trunk, open the trunk, pull out the clearance net, try a couple of times to get both ends in the slots, close the trunk, get back in the car unlatch the to for the second time and now I can FINALLY put my top down!
I hardly ever have anything in my trunk, when I do it is not big enough to poke up past the clearance net, but I have to close the net to put in or pull out whatever goes in the trunk and then pull out the net in case I want to drop the top. It gets real annoying, real quick.
So i decided to find a way to bypass the (I assume it's some type magnetic type) net sensor. I was thinking maybe put a magnet on it or use a resistor to jump the sensor, turns out all you have to do is unplug it! So I unplugged it, used a 10 mm nut driver and pullet the net out. It weight a good 2-3 lbs and taking weight out of my car always puts a smile on my face!
Now i can operate the top with out having to go in the trunk to pull that annoying net out.
Another plus is that it gives yo a couple extra inches if you put something big all the way up against the back of the trunk, which would have been helpful on my trip this last weekend when i shoved some suitcases back there.
Cost of today's mod: Free!
SUX2BU is offline   Reply With Quote
Old 08-08-2011, 02:50 PM   #2
chopper
chopper's Avatar
Drives: 2011 camaro 2ss convertible
Nice sux, Im with you there it is a pain... was that easy to do?
chopper is offline   Reply With Quote
Old 08-08-2011, 02:59 PM   #3
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
VERY! Hardest part was pulling the carpeting wall thing out and using a little screw driver to unplug the sensor.Total time took about 5 min.
Old 08-08-2011, 03:45 PM   #4
dmullen
Drives: 2011 RS Camaro convertible
Thanks for the info...where exactly is the plug?
dmullen is offline   Reply With Quote
Old 08-08-2011, 03:47 PM   #5
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
On the left side behind the carpeted wall where the bar on the net hooks in.
Old 08-08-2011, 07:20 PM   #6
Lightrider
Lightrider's Avatar
Drives: 2011 2SS/RS M6 Hurst Convertible
Hehe...I especially like the weight savings comment you make. Every day, trimming a little here, a little there...getting Ginger into 'bikini' shape soon.
Lightrider is offline   Reply With Quote
Old 08-08-2011, 07:31 PM   #7
billyboyf
Drives: 2011 2LT RS Convertible
This is a great discovery. I got locked out of the trunk for a while the first time I didn't have the net pulled out.I dont put anything in my trunk anyways.
billyboyf is offline   Reply With Quote
Old 08-08-2011, 09:05 PM   #8
mtmtx
mtmtx's Avatar
Drives: 2SS/RS convertible, 6M
Send a message via Yahoo to mtmtx
got nailed by this "feature" a couple of weeks ago...thanks for the tip!
mtmtx is offline   Reply With Quote
Old 08-08-2011, 09:34 PM   #9
united1
united1's Avatar
Drives: slpzl585vert.
Good idea.
Thanks guys<img src=images/smilies/w00t.gif border=0 alt= title=W00t class=inlineimg />
united1 is offline   Reply With Quote
Old 08-08-2011, 09:47 PM   #10
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Just an FYI. You guys don't have to remove the roll out net like I did. You can just unplug the sensor and get the same effect.
Old 08-08-2011, 10:03 PM   #11
Wantconvertible
Wantconvertible's Avatar
Drives: 2011 SS/RS VERT
Thanks for helping,I was showing off one day and the top wouldnt go down,I had to get out to pull it out ,lost my show off stat quick,im going to unplug mine
Thanks again
Wantconvertible is offline   Reply With Quote
Old 08-09-2011, 10:26 AM   #12
RAWarrior
RAWarrior's Avatar
Drives: '11 CGM/IOM 2SS 'vert '02 GMC Envoy
Yeh, got the smackdown by that stupid thing at a car show of all places.
Cyber Grey/Black Conv 2SS IOM interior
12/07/2010 - (1100) Order Placed
12/10/2010 - (2000) Order Accepted by GM Dealer
12/15/2010 - (2500) Order Preferenced Order
12/15/2010 - (3000) Order accepted
01/29/2011 - (3100) Order available to sequence.
01/29/2011 - (3300) Order Scheduled for Production
01/29/2011 - (3400) Order Broadcast
02/07/2011 - (3800) Order produced,
02/07/2011 - (4000) Vehicle available to ship
02/07/2011 - (4104) Bailment Invoice Created
02/07/2011 - (4B00) Your car is bayed
03/12/2011 - She's finally Home!!!!
RAWarrior is offline   Reply With Quote
Old 08-09-2011, 12:21 PM   #13
hwanger24
hwanger24's Avatar
Drives: 11 Camaro Convert 2SS/RS
Do you know if there's any real function to that net being there? Maybe just a precaution so that the owner doesn't drop the top in a packed trunk?
hwanger24 is offline   Reply With Quote
Old 08-09-2011, 12:22 PM   #14
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
That's it's only function. It's to make sure you don't lower the top with no room for it in the trunk.
