02-06-2011, 03:47 AM | #1 |
SS/RS
Drives: 2010 SS/RS IOM w/blk stripes A6 Join Date: Jun 2009
Check engine light
My car has the check engine light on and I want to get it turned off. I installed ARH and CAI right after I got it and the light has been all the time since. I don't want to take it all off to get the light out. I'm going to sell or trade the car off and I don't want the light on. Thanks in advance for the help and advice.
02-06-2011, 05:32 AM | #2 |
Needs to be tuned out by a tuner.
02-06-2011, 06:11 AM | #3 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
Might be your 02 sensor bank 2. Rear sensors. Just have the car tuned and you'll love the way it runs and wont want to sell it
02-06-2011, 06:59 AM | #4 | |
Drives: 2010 Camaro Auto Join Date: Mar 2010
02-06-2011, 10:41 PM | #5 |
SS/RS
Thanks all!!
03-22-2011, 02:38 PM | #6 |
NCCOA Ch 1
Drives: 2010 Camaro 2SS/RS - Z4Z # 44 Join Date: Feb 2011
If its a 01/01 sensor or a 02/01 sensor the issue is before the CATs. Not to worry though, hopefully. Chances are that the sensor(s) have gone bad due to the burn off of residure inside the headers during their initial firing. In other words, the residue that the headers had inside them for storage/shipping burnt off and coated the sensor tips. Try replacing them and you might be surprised to find that you can keep all of the emissions working properly, especially if they are checked in Washington!
If it is a xx/02 sensor it is after the CATS and, as stated above, you can tune them out as they do not have anything to do with the fuel/O2 mixture by the computer. It only reads the input for adjustments from the front O2 sensors.
03-22-2011, 08:05 PM | #7 |
Drives: 1999 Trans Am Join Date: Jul 2009
Needs a tune/tuner. I had a customer complain about the same thing. Had a shop do the headers and the light was on right after.Came to us a month later and on our first scan we found the pass. side 02 was junk from them torching it out of the old exhaust. That month he waited was gas washing the pass. side of the motor.
04-01-2011, 07:51 PM | #8 |
Drives: 2011 CGM RS/2SS, 07 Pont. GXP Join Date: Aug 2010
I had same issue when I installed at cai, set of clear image long tubes and high flow cats....I tried the low-tech method and disconnected the battery at the positive terminal under the hood after I drove about 100 miles to see if the ecu would "learn" the changes, it didn't work. I then disconnected the battery in the trunk and after only 5 minutes reconnected it. The light went off, have not seen it since (about another 100 miles). I have done both normal driving and hard pulls to about 6100 rpm and so far, so good....
04-19-2011, 10:29 PM | #9 |
installed my Volant cai last week. Then it snowed so I didn't get a chance to drive much since the night i installed it. Drove today finally and my CEL came on. Checked all connections and it seems pretty tight. I just unhooked my battery and I'll let you know in a half hour or so if that made the light disappear.
04-19-2011, 11:36 PM | #10 |
It's gone!! Thanks for the tip.
04-20-2011, 08:33 AM | #11 | |
- 2013 Black ZL1 - A6 - Lingenfelter/Cordes Stage 2.5 packages E85 - FORE Fuel System - Kooks LTHs - Magnaflow Cans - Rotofab CAI/Big Gulp/Coolant Tank - Savini 3pc Forged - Underhood Dress Up (ACC & Drake & Moroso) - Hurst Shifter Kit - Custom Audio w/ JL Audio Sub/Amp/Stealthbox - Hand Polished Brace - Oracle Ghost Sidemarkers - LEDs everywhere - 624/617 on E85 & 545/548 on 91 (Sept 2015) - 693rwhp (Dec 15)
04-20-2011, 08:35 AM | #12 | |
For the OP, this code will need to be tuned out, and is the common CEL after headers/hi flos/CAI...(right?)
04-20-2011, 09:39 PM | #13 | |
Drives: jealous vendors mad!! HAHA!! Join Date: Jan 2011
I've been running with my cel for about a month but the only thing i notice is my car idling a little louder and rougher but i might just be hearing my long tube and no cats |
Similar Threads | ||||
Engine Misfire when cold, Check Engine Light | TooCool5 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 19 | 08-28-2013 01:07 PM |
Acronyms? | KEEP RT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 03-11-2011 08:57 PM |
Check Engine Light | twnorman | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 3 | 01-23-2011 07:32 PM |
Check Engine Light... | Missionboi | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 1 | 01-08-2011 01:02 AM |
P0300 Misfire Code Help | black-knight | 4th Generation Camaros | 4 | 02-08-2010 01:45 PM |
