04-10-2023, 08:36 AM | #1 |
Drives: 2019 Chevrolet Camaro SS Join Date: Apr 2021
Procharger and 2-Step
Anyone have any experience using a 2-step on a procharged car? Was testing and couldn’t rev past 2700, it was pushing through the brakes. But because of only being able to go about 1/2 throttle, i wasn’t able to close my BOV so it left the line really slow. How much boost have you seen on a similar set up?
Currently waiting on the 10 Speed Launchbox to be released so i can use that as a trans brake |
04-10-2023, 10:53 AM | #2 | |
Drives: 2018 Camaro ZL1 A10 Join Date: Feb 2022
IMO, 2-step will still eventually push through the brakes. T-brake is the only solution to help build boost of the line https://www.camaro6.com/forums/showthread.php?t=592876 |
04-10-2023, 10:56 AM | #3 | |
Drives: 21 Lt1 Join Date: Dec 2016
21 Camaro LT1 Fully forged, Katech ported stock heads, P1X,3.7 upper and ATI w/ 8.25 lower, Stage 2 intercooler, Race B.O.V, Btr stage 2 blower cam, Btr Trinity intake, 103mm TB, F.I.C +30’s, Fore innovations, LPE big bore pump, Weld Lagunas Drag Pack. Circle D TC. Full Bmr upgrades, Keltrac rear shocks.
04-10-2023, 11:22 AM | #4 |
[QUOTE=ZL14ever;11304239]I thought it was already released for the A10? I think I saw something on Facebook
IMO, 2-step will still eventually push through the brakes. T-brake is the only solution to help build boost of the line https://www.camaro6.com/forums/showthread.php?t=592876[/QUOTE probably only gonna take it to 2700 to 2800 RPM on the two-step. maybe 3k just want to be able to go full throttle so that I can start to build boost and get off the line quicker |
04-10-2023, 11:32 AM | #5 |
i’m super excited for that tbrake. i’ve told him that i’ll be getting one as soon as they’re available. really interested to see how far i can take this trans power wise. i think he said he’s making 900 something to the wheels
04-10-2023, 06:08 PM | #6 |
Drives: 98 Camaro Join Date: Apr 2022
Been thinking about a 2-step for mine. P1x with lt4 fueling. I had one on my 4th Gen and foot braked it. Went my best 60ft with it. Procharger could definitely use it. Best 60ft I’ve been able to get with stock converter is 1.70
04-10-2023, 07:30 PM | #7 |
so you would definitely say that using a 2-step with procharger is helpful?
04-10-2023, 08:18 PM | #8 |
I had one on my turbo vette and my 4th Gen. They both worked well. I think it would definitely help the 60ft on the 6th Gen with Procharger. Go from leaving on no boost to a few psi
04-11-2023, 07:19 AM | #9 |
right on, hopefully the weather stays clear so i can get out and do some testing and i’ll see if i can’t push it to 3 psi. i’d be happy with even 2
04-11-2023, 08:16 AM | #10 | |
www.jannettyracing.com
04-11-2023, 08:45 AM | #11 |
04-11-2023, 08:48 AM | #12 | |
If you don't you can move to a Tial Valve we carry with a very light spring. 203-753-7223 It closes with a lot less throttle input.
04-11-2023, 09:02 AM | #13 |
i had to go double check the order but it appears that i indeed did upgrade to the race bypass
04-11-2023, 09:15 AM | #14 | |
BAMF SS
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
10 speed, 2 step, boost, cammed, procharger |
Thread Tools | |
