04-26-2022, 02:36 AM | #1 |
Drives: Chevy Camaro ss Join Date: May 2019
Cammed l99 rpm issues
I have a 2010 ss camaro with the l99 auto. Recently had a btr stage 2 cam installed with a circle d triple disc 2800-3000 stall convertor. Also had heads port and polished. Doesnt do this all the time but every once in a while the car will stall out when putting it in drive. Also does the same when putting it in reverse. Seems to do it alot more in reverse. Doesnt do it when applying throttle tho. The car also surges when decelerating. Anybody have any ideas on what might be causing this? A buddy said to check rpm idle, but it idles around 750 to 850 or so. Also the rpms are never steady. They are always bouncing up and down constantly at all speeds. Is this normal in a cammed car? Retune? Vaccume leak? Any help is greatly appreciated thanks in advance
04-26-2022, 05:55 AM | #2 |
The surging might be the lock up converter which you can have tuned out of all the gears you want to. I have mine set to not lock up until 5th and 6th. As for the other issues that you talk about are all tuning issues that need to be addressed by your tuner.
04-26-2022, 02:16 PM | #3 |
Drives: 2010 Camaro 2SS/RS A6 Join Date: Jul 2021
My SS3 VVT cam with 36-3800 stall surges occasionally after a warm start until first throttle application. GPI tuner (Ben) couldn't work that out but not really a big deal. Mine is set to idle at about 850 rpms once warm. Never experienced it stalling out. Mine bucks a little when decelerating from 40 to 20 mph or so, but that's normal. RPMs always steady once warm. It sounds like your problems can probably be tuned out mostly.
2010 2SS/RS A6. GPI SS3 VVT Cam, 228/246 / AFM Delete / Circle D 4C 36-3800 Stall / Stainless Works LTHs, High Flow Cats, X-pipe, Borla Pro XS Mufflers and Quad Tips / Vararam CAI / Soler 95mm PTB / AAM 3.91 gear / GPI Ported Heads / GPI Ported Rod Mod Intake Manifold/ Smith Bros. Trunnions / GPI 5/16" hardened push rods, 7.425"/ Chevrolet Racing Lifters / Melling 10355 Oil Pump / Powermaster XS Torque Starter / Derale Xmsn Cooler / 1LE Suspension Upgrade System / BMR Strut Tower Brace, Trailing Arms and Toe Rods / Powerbond 25% UDP / Mishimoto catch can / iDatalink Maestro.
04-26-2022, 03:25 PM | #4 |
Drives: 2011 Camaro SS Join Date: Jul 2019
Cam Motion cam and 3200 Circle D stall. Have some surging at 1000rpm...but never stalled.
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
04-27-2022, 06:23 AM | #5 |
GPI Sales Consultant
Tuning issues... driveability takes lots of time to really get perfect. Some are more sensitive than others.
Got a question about a GPI product? Feel free to shoot me a message! |
04-27-2022, 06:25 AM | #6 |
Evil Genius of Chevrolet
Definitely your tune.
04-27-2022, 07:21 AM | #7 |
^^^ This, it is all in the tune, and as cammer said, sometimes it takes a bit of time to work out the "driveability" on the dyno, so the driving on the street will be clean and smooth. My Camaro drives like a dream with the big cam and stall, never had any issues with stalling and bucking no matter how fast or slow I'm going. Sounds like a converter lockup/unlock timing issue. Good luck.
04-27-2022, 07:32 AM | #8 |
Started#gottalovethatblue
Definitely sounds like a tune issue to me, especially the stalling out part. I have a BTR stage 2 cam and while I’m still running a stock converter, it doesn’t want to die on me. It will buck a little <5mph, but that’s partially the stall and I think partially the tune on mine. I’d go back and have them retune yours for sure.
bucking, cammed, l99, rpm issues, surging |
Thread Tools | |
