Old 05-03-2018, 08:05 AM   #1
GuywithL86
Drives: Black
2019 gm v8 truck specs released
http://gmauthority.com/blog/2018/04/...ings-revealed/
As many of you know the current l86 motor has the same long block as the lt1. All the internals, head, cam, valvetrain are all part number for part number identical. Not sure if this trend will continue with the new trucks. But the specs were leaked regardless.
L86 (‘14-‘18)= 460ft lbs, 420hp
L87 (‘19+) = 450ftlbs, 425hp. Afm now allows multiple configurations and it will even run on 1 cylinder now, and have start stop.
GuywithL86 is offline   Reply With Quote
Old 05-03-2018, 09:27 AM   #2
ISHLISS
Chevy & Ford Enthusiast
ISHLISS's Avatar
Drives: '21 Camaro LT1
I think i'm one of the few who actually love the new Silverado. Surprised they went down in torque on the 6.2L and no change on the 5.3L.
ISHLISS is offline   Reply With Quote
Old 05-03-2018, 09:33 AM   #3
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I'm with you. I'm a really big fan.
Old 05-03-2018, 09:51 AM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
looks much better then the 2019 Camaro.
2016 NFG SS A8/Whipple 2.9/Fuel System/Flex Fuel
Old 05-03-2018, 02:09 PM   #5
oldman
Drives: SS 6 speed of course
OOOOOUCH.....
oldman is offline   Reply With Quote
Old 05-03-2018, 03:05 PM   #6
WILWAXU
WILWAXU's Avatar
Drives: 2019 Crush ZL1 1LE
Wink
Well.. if that's your benchmark
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
WILWAXU is offline   Reply With Quote
Old 05-03-2018, 03:55 PM   #7
KingLT1
KingLT1's Avatar
Nope it's not. I prefer the looks of the 17-18 Silverado over the 19. Just saying the 2019 truck refresh is the least offensive of the 2.
Old 05-03-2018, 05:35 PM   #8
Childs Play
Pizza & Wings Only $12.99
Childs Play's Avatar
Drives: 2017 Camaro SS
One cylinder. Interesting...
Basically a Silverado powered at times with a weed wacker.
H-Town Camaro Club
Past Rides:
2012 Camaro 2SS/RS M6
2012 Camaro ZL1 A6
2017 Camaro 2SS M6
Childs Play is offline   Reply With Quote
Old 05-03-2018, 05:54 PM   #9
Mr. Wyndham
A 775 cc weed-wacker...
That said...they can shut cylinders down with a single cycle...basically saving fuel one squirt at a time!
Old 05-04-2018, 01:06 AM   #10
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
no fuel is saved by afm in the silverado. 4cly is not enough to maintain speed
Old 05-04-2018, 06:12 AM   #11
GuywithL86
Drives: Black
Flat road, when all the trans, diff, and transfer case fluids are up to temp (takes a solid 20-30minutes), I’m cruising in v4 getting 22-23mpg at 75mph, done it numerous times for long distances.
Old 05-04-2018, 06:32 AM   #12
motorhead
Drop torque in a pickup. Boy the hits just keep coming. Im sure you have to get the top model to get the 6.2 again which is crap. Does anyone have pics of the GMC version?
Old 05-04-2018, 10:45 AM   #13
KingLT1
KingLT1's Avatar
Originally Posted by GuywithL86 View Post
Flat road.
key word.
Old 05-04-2018, 11:35 AM   #14
GuywithL86
Drives: Black
btw, google laura GMC if anybody is interested in one
cheapest and highest volume dealer in the country
Loaded slt crew cab with the 6.2 you can usually pickup for $40-$42k.
