Old 07-29-2017, 04:10 PM   #1
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Any handymen here
I work at a computer all day so I have a lot to learn in the "working with your hands" fields.
What size and type of electric sander would recommend for a med/large deck and an older playset. The objective is to re-stain both afterward.
Thanks!
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
Old 07-29-2017, 05:27 PM   #2
Trickskier
Native Floridian
Trickskier's Avatar
Are the surfaces that rough? A lot of splinters? Post some pics.
Old 07-29-2017, 05:30 PM   #3
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Not terrible in my opinion. Just at the do or die point I'd guess.
Old 07-29-2017, 07:57 PM   #4
jrhagen
Drives: Camaro
Just pressure wash them. Faster and easier. You can rent a pressure washer from Lowe's or Home Depot for the day for about $50.
jrhagen is offline   Reply With Quote
Old 07-29-2017, 08:25 PM   #5
Trickskier
Native Floridian
Trickskier's Avatar
Agreed - Just pressure wash. Then just re-stain. May take several coats to sink in.
Old 07-29-2017, 08:49 PM   #6
jrhagen
Drives: Camaro
Remember a pressure washer isn't a toy. It will slice right through skin.
Old 07-30-2017, 09:14 AM   #7
Lou gill
Lou gill's Avatar
Drives: ‘13 ZL1 convertible
You are correct on sanding, using a pressure washer and driving water into the wood makes zero sense if you are going to stain or paint. In addition pressure washing will raise the grain of the wood for a rougher surface. Rent a floor sander for the main part of the deck, and pick up a palm sander for the rest. It will take awhile, but remember a good paint or stain job is all in the prep.
Lou gill is offline   Reply With Quote
Old 07-30-2017, 09:45 AM   #8
jrhagen
Drives: Camaro
There you have it, 2 suggestions. Fast and easy or long and hard. The choice is yours to make.
Old 07-30-2017, 10:40 AM   #9
Infern0
Bring It
Infern0's Avatar
Drives: In Between
lol. I was hoping there'd be a right and wrong to make things a little more decisive.
I just picked up the playset and I was told it had already been pressure washed. I can tell that's probably true though looks like it was done gently.
I was thinking of gently pressure washing the deck anyway to get the dirt and some black stuff (maybe mold?) off of the surface.
The surfaces on both the deck and the playset aren't rough by any means at the moment. Virtually no risk of splinters even. I asked about sanding because I was perhaps under the wrong impression that it was a requisite to staining. If sanding would only be considered a requirement if the surfaces were rough, maybe it isn't necessary after all?
Thoughts?
Old 07-30-2017, 11:23 AM   #10
jrhagen
Drives: Camaro
Thoughts?
Sounds good to me, but I'm kinda lazy when it comes to stuff like that.
Old 07-30-2017, 12:12 PM   #11
imaSSnake
'Maro
imaSSnake's Avatar
Drives: 2015 SS 6.2L Auto 2SS
Thoughts?
I've owned my own business before, and full time maintenance now.
That definitely does not require sanding. Good pressure wash and you're good to go, as said earlier in the thread.
You're actually taking care of Maintenance before most people would on your deck and playset
2015 SS 2SS Auto 93 SCT Perf, Kooks LTH & HFC MBRP Axleback Muffler Delete "Z/28" Spoiler and Grille OEM ZL1 wheels 285/305/35R20 BFG G-force Pro Comp 2
imaSSnake is offline   Reply With Quote
Old 07-30-2017, 12:14 PM   #12
imaSSnake
'Maro
imaSSnake's Avatar
There is even a product to rejuvenate the deck to freshen it up before you stain it if you wanted to use it, but it doesn't look like it really needs that so I would just pressure wash and let it dry and stain
Old 07-30-2017, 12:18 PM   #13
jrhagen
Drives: Camaro
3 pressure wash, 1 sand. Just saying.
Old 07-30-2017, 12:59 PM   #14
sherob
sherob's Avatar
Drives: 2015 SW 1SS/RS 1LE
Definitely PW, let it dry really good, then stain away... the pics don't show the need to sand yet, so sanding is just a waste of time.
