TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - California
Old 03-07-2018, 03:29 PM   #57
HAMBO
HAMBO's Avatar
Drives: Supercharged 2013 AGM 2SS/RS
Update: Added GM LS3 Heads and Cam upgrade kit. An exciting addition!
https://arb.ca.gov/msprog/aftermkt/d...o/D-126-45.pdf
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports.
1967 Bolero Red 396 SS/RS Convertible
HAMBO is offline   Reply With Quote
Old 03-29-2018, 01:19 PM   #58
HAMBO
HAMBO's Avatar
Update: Adding, from what I understand, is the first and only CAI approved for the 5th gen SS!
Powerteq Jammer CAI:
https://arb.ca.gov/msprog/aftermkt/devices/eo/D-802.pdf
2013 AGM 2SS/RS
Old 04-01-2018, 05:52 PM   #59
51LE50
51LE50's Avatar
Drives: 2015 1LE, 2SS, Bright Yellow
This is awesome!
51LE50 is offline   Reply With Quote
Old 04-01-2018, 10:13 PM   #60
Mrgwrnch
Pay attention to details
Mrgwrnch's Avatar
Drives: 2012 ZL1
Originally Posted by HAMBO View Post
My guess is they would fit, but the consensus generally seems to be shorties deliver negligible gains at most, and (IMO) aren't worth the cost of parts and labor.
If you are looking to spend some money on a CARB legal part, there's (oddly enough) a CARB legal CAI for the 2014 ZL1 only...
https://www.knfilters.com/search/pro...cid=ADDCABINAI
Not sure how it happened, but there it is.
I looked at K&Ns website and found that this system is "
Not legal for sale or use in California".
Mrgwrnch is offline   Reply With Quote
Old 04-01-2018, 10:20 PM   #61
HAMBO
HAMBO's Avatar
That's odd. It's described on the K&N website as "50 state legal", and the 2014 Camaro ZL1 is listed in the ARB E.O. here:
https://arb.ca.gov/msprog/aftermkt/d...o/D-269-49.pdf
You might want to call K&N and clarify. Seems it shouldn't be an issue.
2013 AGM 2SS/RS
Old 07-03-2018, 11:33 AM   #62
HAMBO
HAMBO's Avatar
Added Comp Cams 50-state legal package for the SS!
2013 AGM 2SS/RS
Old 12-04-2021, 12:20 AM   #63
Iceintheback
Iceintheback's Avatar
Drives: 15 Commemorative Edition Camaro 2SS
So, it seems that every one of your links is no longer active which tells me that those money grubbing A-Holes have removed whatever approval there might have been for these items... Unbelievable!
Iceintheback is offline   Reply With Quote
Old 12-04-2021, 01:02 AM   #64
Iceintheback
Thank You.. As a CA resident and with very limited CARB approved items, this was a great find. Just ordered it.
Old 07-26-2023, 05:51 PM   #65
c-57d
Drives: 14 2SS/RS Triple Black Ragtop LS3
The links are no longer valid.
The EO numbers can be chased manually on the CARB site.
Come see the violence inherent in the sysadmin.
c-57d is offline   Reply With Quote
