#1 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 92 Luminadead/01 Dakota/97 F150 4x4 Join Date: Jul 2009
Need help with 99 Silverado Z71
I bought a Silverado and am in need of a new ignition. Problem is that GM apparently offered 4 different ignitions on them in 99. I was wondering if anyone here would be able to look it up in a GM service system and tell me what ignition I need with the VIN. it would be greatly appreciated!
#2 |
ttt
#3 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS/RS - 2004 Silverado Join Date: Mar 2010
Which body style do you have? 1999 was a transition year for the Silverado. Do you have the '88-'99 style or '99-'07 style? The older style will have a 5.7 350 engine with a distributor ignition and the newer style engine (5.3/4.8) has a coil pack on each cylinder. This is probably why there are 4 different ignition systems offered in 1999........
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80 2004 Black Silverado 1500 2WD Regular Cab, Short Bed -5.3 LM7, 4L60E, 3.42, G80 2014 White Caprice PPV -6.0 L77, 6L80E, 2.92, G80 |
#4 | |
#5 |
I would go to the parts department at your local Chevy dealership, give them your VIN, and get the part numbers for the coils (if that is the issue you're having). If you like the price, get them there. If not, at least you now have the part numbers and you could look somewhere else.
