02-19-2015, 08:29 PM | #1 |
Drives: 2010 camaro ss Join Date: Oct 2011
Help! Fast fuel rail ,fuel line DIY
Any body have a DIY on fast fuel rail lines can't seen to find them for sale online ,guessing everybody making them custom?
02-19-2015, 09:18 PM | #2 |
http://www.speedengineeringlsx.com/f...rails-54028frc
Ok found the rear cross over line ,any logical reason nobody makes a direct bolt on kit , I'm also installing fast manifold and nick William 102 TB ,would I need a retune , running turbonectic kit right now |
02-20-2015, 05:51 PM | #3 |
Drives: camaro ss\rs Join Date: Jun 2014
you have to use an adaption 3/8 gm to -6an. after that choise a connector you prefer to do the fuel line. of course you need also a -6 an hose
02-20-2015, 06:09 PM | #4 |
Drives: 2006 Z06 Join Date: Oct 2010
Stay with stock intake. Fast are known to leak and blow apart with boost, and it will add little if any power.
Yes would need a retune, but staying with stock intake/tb is a much better idea.
Nick
Corvette Z06 -1200ish rwhp |
02-20-2015, 06:38 PM | #5 | |
http://m.summitracing.com/parts/rus-644123 Found a shop close by call the hose man gonna see Tommorow if the can make the line for me -6 an line ,any info will appreciated |
02-20-2015, 06:44 PM | #6 |
Ok cool ,Yeah I read somewhere some going caboom on high boost , I'm staying on 7 pound of boost not going any higher than that , I ll keep my stock one if it fails 😁
02-21-2015, 06:46 AM | #7 | |
I suggest the holley rail.they come as a kit with hose and fitting. You just need a cap for one side. I'm not running a supercharger or procharger but it looks like a state of art. |
02-21-2015, 08:36 AM | #8 |
The money can be spent elsewhere for much better returns. And even at 7psi they have failed. Sadly when they fail, they can take the whole motor with them. I wouldn't even consider it. Use the $1500+ your are going to spend, and put it in to tires/suspension, good boost controller, meth, a cam, or something that will help. This is big money to just add a risk of failing.
Nick
02-21-2015, 09:07 PM | #9 | |
It's all hers.
Drives: 2015 ZL1 Join Date: Jan 2012
02-21-2015, 09:21 PM | #10 |
I have the Holley rails and had a buddy make me up some lines.
02-21-2015, 09:35 PM | #11 |
It's all hers.
And there's no right or wrong way when deciding if the cross-over line should be in the front of rear. It's all up to you and what you prefer. I opt'd to do the cross-over in the front.
02-22-2015, 01:07 AM | #12 |
Oh and Russell 644123 is the 3/8 to 6an addaptor you will need.
02-22-2015, 07:41 AM | #13 | |
Fuel rails $200 Fuel rail line kit $150 NW 102 $550 Retune for that ~0-500 $1500 is a easy low estimate for what he is doing. Just trying to help another person from making the same mistake, and potentially losing a motor.
Nick
02-22-2015, 10:17 AM | #14 |
Best bang for the buck fuel rails out there are the Holley by far. Less than $150
