07-22-2023, 04:15 PM | #1 |
Drives: 2010 Camaro SS 2SS Join Date: Aug 2016
Mud flaps / splash gaurds
Can anyone recommend where I can purchase rear mud flaps for my 2010 SS, Preferably in body color? My new rear tires are a little wide for the body and looks a bit strange from behind.
07-23-2023, 10:32 AM | #2 |
Drives: 2010 Camaro 2SS L99 Join Date: Apr 2023
I think most people who put splash guards on their Camaro go with the rock guards from ZL1 addon, I've had mine for a while now have had zero problems, not sure how much they will help with hiding a wider tire though.
https://zl1addons.com/collections/ro...15-rock-guards
Behind every scratch is a story on what not to do, and my car has a lot of stories.
07-23-2023, 11:18 AM | #3 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
I know back in the day GM, used to offer body colored splash guards. Not sure if they are even still available, I ended up with the ZL1 addons on mine they work fine. But they only come in black.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
07-23-2023, 12:14 PM | #4 |
These indicate they are for 2012-2013. Any reason they wont fit on my 2010?
07-23-2023, 12:34 PM | #5 |
Drives: 2010 ABM Camaro SS M6 Join Date: Jul 2020
I ended up getting two different options. First was the ZL1 Add-Ons. I like the stealth look and it ships fast, which was important considering I put on big tires and it was kicking up gravel. However, it isn't body colored like you asked for. Additionally, I don't like how to only uses glue to connect to the car when it's a 2010 (glued blocks to your car and then the mudflaps screw into the blocks). However, this is what's on my car right now and despite my fears, the glue has so far held.
Second, I got the RPI Designs that can color match. I haven't put them on yet - the con here is that it took a while for them to arrive. From the pictures I've seen other members post, I like the looks of them. Not quite as stealth however. I've attached a picture from joekono's car. https://www.rpidesigns.com/shop/item.aspx?itemid=1922 |
07-23-2023, 01:20 PM | #6 |
They will fit a 2010-2015 Camaro. Nothing back there has changed until the 6th gen came out. 2016 up..
07-23-2023, 01:23 PM | #7 | |
07-25-2023, 01:20 AM | #8 | |
Drives: Camaro Convertible 2014 1LT Join Date: May 2019
