05-09-2023, 06:48 AM | #1 |
Drives: 2015 ls, 2015 Silverado LTZ Join Date: Jun 2020
Lift Pads
I ordered a set of Lift Pads from ZL1 Addons. Any tips? Should I lock tite the bolts? Has anyone ever lost one on the road?
05-09-2023, 07:04 AM | #2 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
Recently did the same thing. I have a feeling if you dont locktite them, they will fall off. Havent installed mine yet. After thinking about it, I think I will just install them as needed.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
05-09-2023, 07:07 AM | #3 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
I used Loctite on mine as insurance. Just be sure to BLUE, and not RED. Just in case you ever need to remove them.
05-09-2023, 08:56 AM | #4 |
^^ this is what I did on mine.
05-09-2023, 09:16 AM | #5 |
Drives: 2012 SS Join Date: Dec 2021
used loctite also
2012 Camaro SS
05-09-2023, 10:32 AM | #6 |
ive been using this for home use as i use it on my daily as well
https://www.amazon.com/dp/B073SQRYB3...9C86KE7AC46E4K i was looking at these to mount on the camaro https://a.co/d/91kwssr
David Vianu
2010 Synergy Green 1LT |
05-09-2023, 10:32 AM | #7 |
I have a set on my car that I put on soon after I bought it in 2018.
Did not use loctite, just as tight as I could do by hand. They have not budged since.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Mishimoto Oil Cooler, BMR Tunnel Brace, Mishimoto Oil Catch Can, MSD Plug Wires, Mishimoto Radiator and Hoses. |
05-09-2023, 12:07 PM | #8 |
Drives: 2015 Z/22 Join Date: Aug 2015
A hockey puck works great and costs about $1, and can't fall off.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
05-09-2023, 01:38 PM | #9 |
Drives: 2010 Camaro 2SS L99 Join Date: Apr 2023
I installed mine without loctite, remember my dad too one look at that and said "I bet you'll have 3 by the end of the year and only 2 left after about 2" but about a year in and they're still holding
Behind every scratch is a story on what not to do, and my car has a lot of stories.
05-09-2023, 03:02 PM | #10 |
Drives: 2016 1SS Join Date: Apr 2012
Lift Pad Install
We have had our ZL1 ADDONS LIFT PADS installed without loctite for a few years now with no issues.
However if you do use Loctite, as others have said be sure to use blue! |
05-09-2023, 04:39 PM | #11 | |
Drives: 2010 Synergy Camaro Join Date: Apr 2023
05-09-2023, 07:47 PM | #12 | |
Drives: 2010 2LT/RS Join Date: Mar 2015
^^^^ What he said.. I did not use loctite at all either and they are still on the car as tight as I could do by hand as well!
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
05-11-2023, 11:57 AM | #13 |
I used loctite on mine as added insurance. Never hurts to have that. Better than having it fly out from under your car and flying thru another cars windshield on the road.
Custom TSP Stage 2 Cam/GPI intake Ported Rod Mod /VARARAM CAI/Mishimoto Catch Can/1 LE front & rear sway bars/ engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill. |
06-13-2023, 01:10 PM | #14 |
Drives: 2010 2SS/RS Join Date: May 2015
If you look at the length of the Allen screws, and you run the screw all the way in you do not have many threads of the screw in the screw hole. I put in longer Allen screws, 1/4” X 28 thread, so the screw has more bearing load in the threaded hole. Had to use a 1/4” ratchet with the Allen attachment as an Allen wrench alone was pitiful.
