10-01-2019, 12:43 PM | #1 |
Drives: 2019 ZL1 Join Date: Jul 2019
ECS/Vortech tuner kit (Novi 1500) install times and fair pricing?
I was just looking for a bit of insight on installation times and prices for people who have had a similar or any other SC setup installed. As the title suggests, I have an ECS/Vortech supercharger kit with the Paxton 1500, if that matters and will be going on a 2018 SS A8.
I’ve reached out to different shops; some of them are quoting up to $1900 just for the installation, all the way down to $1250 for installation. One of the shops whom I favor over the others is saying the installation time is around 13-15 hours which sounds a little long for how uninvolved this kit is. I’ve seen around that people who DIY the kit had gotten it done in around 8 hours, and even the kit advertises 7-10 hours. So, for others who have recently gotten an ECS/Vortech supercharger, or any other SC like procharger installed, what was a fair price for the installation and how long was the install? Last edited by federal; 10-01-2019 at 12:53 PM. |
10-01-2019, 06:31 PM | #2 |
1500.00 is about the going rate for a supercharger install. I would be more cautious on who you let tune it. That is the make or break factor. Majority of shops out there have no business tuning gen5 stuff just because they can tune gen 3&4 LS.
2016 NFG 1SS A8
10-01-2019, 08:48 PM | #3 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
As one who has put one on myself - it's not that anything there is really hard to do, it is just a lot of stuff to do. There is a lot of hardware around the end of the frame rails that have to come off in order to get down to a spot in which you put the intercooler in.
ECS has dealers all across the country - they may have someone local who has done one. If they do, they know how to get thru all of the parts that need modified and will probably be able to do it in less time.
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
10-02-2019, 07:15 AM | #4 | |
Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
^^^^^ x 1000. I wasted good money letting an LS tuner who said he can tune the Gen 5 tune my car after the fiasco I had with prochargers canned tune. He had no clue what he was doing. Don't make the same mistake.
Former Ride: 17 Camaro 2SS, M6 - Fifty | Procharger P1SC | 3.7 Pulley | Stage 2 IC | Race Bypass | DSX FF Kit | JRE Custom E85 Flex Fuel Tune | LT4 Fuel System | JMS Voltage Booster | MSD Plug Wires | American Racing 1-7/8's LT Headers Full System Catback | Baro Breakout Harness | LT4 Map Sensor | Katech Ported TB | MMS Oil Catch Can | 160 Thermo | Solo Performance J-Pipes
07-11-2020, 03:20 AM | #5 |
Drives: 2018 camaro ss1 Join Date: Jul 2020
ECS supercharger
Has anyone had a bad experience wlth ESC supercharger kit as of late? Recommended by an installer that did alot of work for Lethal garage:also with an ARH headers...is that a good fit for my 2018 ss?? taking all comments thanks
07-11-2020, 03:53 AM | #6 | |
Other than that, zero problems. Very easy to maintain and change the oil. No belt slip due to the toothed pully and belt. On stock fueling, I’m making 610rwhp, 560 some tq on almost 9 lbs of boost. I was a little concerned with some heat soaking, so I got the Anderson Composites ZL1 style hood which has really introduced a ton of airflow and very dramatically reduced my IATs. I say go for it, especially if you can get it for a good deal. I got mine “used” from a member here for $4500 if I recall correctly, and then installation and dyno tuning was $2k. Edit: The one gripe I have about it would be the “heat shield” below the air filter, which is basically a pretty thin piece of steel. I’m not sure how much it made a difference, or if it was even needed due to the intercooler, but I put some heat reflecting material (same stuff that’s on my carbon fiber hood) on it to stop some of the heat from coming up from the manifold. Don’t mind the dirty engine bay, but it’s a pretty compact and nice looking setup, IMO!
2019 Camaro ZL1
07-11-2020, 04:17 AM | #7 | |
Drives: 2017 Camaro 1SS Join Date: Aug 2016
07-11-2020, 07:05 AM | #8 | |
07-11-2020, 01:26 PM | #9 | |
2019 Camaro ZL1
07-11-2020, 05:50 PM | #10 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Curious how much the anderson composites hood actually reduced IATs
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
07-11-2020, 06:45 PM | #11 | |
I’d be curious as well how effective it is during this summer heat, but for that, I have no idea. I’ll take some notes of temps next time I’m out.
2019 Camaro ZL1
07-11-2020, 07:50 PM | #12 | |
Anderson should advertise that
16 1SS M6 White
07-12-2020, 02:56 AM | #13 |
The heat evacuation on it is also pretty awesome. Obviously the stock SS hoods only have those two, small vents on them and are very insufficient... but with the AZ hood, all you see after a few runs is all that heat distortion flowing out.
2019 Camaro ZL1
07-12-2020, 05:28 AM | #14 |
Ok, so the car was actually making 488 rwhp. Therefore it's not a surprise that the stock fuel system was able to keep up. That was my point, when someone mentions how much hp they made with the LT1 fuel system, the actual power is the one that matters, not corrected.
