Old 08-26-2019, 07:04 PM   #113
jeremyeliseo
Drives: 2016 Chevrolet Camaro 2SS M6
Clocked time with NLS.
My question is, when performing test that GM uses to advertise performance times is the NLS feature used? For example I was trying my best 0-60 and without using NLS I was rarely able to go below a 5.0 sec. but when I used the NLS feature I was able to get a 0-60 of 3.9sec on my stock 2016 2SS.
jeremyeliseo is offline   Reply With Quote
Old 11-25-2019, 10:43 AM   #114
Midblues
Drives: Chevy Camaro 2019 Turbo 4 LT 6sp
When you disable vehicle dynamic control or all driving aids with the center console button. Dose this also disable NLS?
Midblues is offline   Reply With Quote
Old 11-25-2019, 10:49 AM   #115
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
They were definitely using it. It's the fastest way.
No it does not.
But I will say, if you ever so slightly lift off the gas it will disable and you'll miss a gear.
Old 02-24-2020, 01:20 PM   #116
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
That's quite a big spread, I might vary a tenth or two between using nls or not.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 02-24-2020, 02:40 PM   #117
RobbyBeefcake87
Thanks everyone for the replies. Question for 2.0 turbo drivers, now that I have changed oil I am getting on it a little more and tried this NLS so my question is when I do it very smooth sifts no power loss but turbo seems to make a fart noise like an exhaust brake on a truck,is this normal for 2.0 drivers? Sorry so many questions new to NLS and turbos learning as I go.
The v8 ss makes the fart sound too, usually easy to tell when people nls because of that sound. Its normal imo, probably has to do with the manifold pressure being maintained but it cutting spark.
Old 11-26-2022, 11:41 PM   #118
KirillWA
KirillWA's Avatar
Drives: 2022 Camaro 1SS 1LE
Is anyone using no lift shift on the track? I'm wondering if after entering the straight I should use regular 2->3->4 shifts, or stick to nls?
Will nls harm the transmission or the clutch long term, with 20-30 track days a year? Or it doesn't worth it time vise?
After learning how to do nls properly I started to use it on the long straights, but use regular shifting elsewhere on the track.
2022 Camaro 1SS 1LE Rapid Blue 6MT
Looking for traction on wet pavement in Seattle.
KirillWA is offline   Reply With Quote
Old 11-27-2022, 09:04 AM   #119
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
With me it kind of depends on the straights but yes I use it and it and it's definitely not going to harm anything long term. It's just a smoother, faster shift however on a road track probably little if any affect on time.
I say keep doing it when appropriate.
Old 05-25-2023, 06:42 PM   #120
KirillWA
KirillWA's Avatar
Hey folks,
It's me again.
I was using no lift shift almost exclusively on the track yesterday, trying different RPMs. I've learned that switching to the next gear with NLS when you see yellow lights on the windshield projection instead of red lights leads to a way smoother shift. There is no "BRRR" sound like when you do it closer to 6000-6200rpm and see red lights.
Was I doing it wrong all the time? Green lights, yellow lights, red lights and then NLS before red lights start to flash. You have slight kick and hear loud BRRR from the exhaust when shifting.
If you shift at yellow lights, there is no exhaust BRRR sound and it feels way smoother. But is it the fastest way to accelerate on the straight on track?
Old 05-29-2023, 03:12 PM   #121
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I use 6000-6500 rpm
carguy55 is offline   Reply With Quote
Old 05-29-2023, 03:37 PM   #122
Canyonero
Canyonero's Avatar
Drives: F-Series Canyonero
I've tried a couple times on the 3-4 and it shifted really harsh. I'm not sure if it's something I did or if NLS has any known problems that could be diagnosed.
It's not something I want to reproduce for a mechanic on a public road.
Canyonero is offline   Reply With Quote
Old 06-14-2023, 01:58 PM   #123
KirillWA
KirillWA's Avatar
Originally Posted by carguy55 View Post
I use 6000-6500 rpm
Do you see yellow lights or red lights on the windshield projection when you do NLS? I assume 6200 should be red.
Old 08-01-2023, 02:18 PM   #124
Briland_1LE
Briland_1LE's Avatar
Drives: 2020 Camaro SS 1LE
It does not matter at all what color the lights on the HUD are, you just use NLS when you want as long as your a good bit above 5k rpm to do a fast WOT shift, that's it. The weird BRR sound is not bad its just part of the NLS tuning to lower rpm.
Briland_1LE is offline   Reply With Quote
Old 08-03-2023, 08:39 AM   #125
Hostile_1LE
Hostile_1LE's Avatar
Drives: 2020 Camaro SS 1LE | Satin Steel
I've tried using NLS recently on my '20 SS 1LE, and it seems it either doesn't work, or it goes to 6400 rpm instead of 5000. It feels like I'm doing a regular power shift with no rpm drop until I dump the clutch. Any ideas as to why it is like this?
GPI SS3 / GPI ported heads | MSD Atomic / NW 103mm | 1 7/8th LTH | Roto-Fab CAI | FlexFuel | Tuned by GPI |
xxx Hp / xxx tq
Hostile_1LE is offline   Reply With Quote
Old 08-03-2023, 10:18 AM   #126
Canyonero
Canyonero's Avatar
Same Here. Stock 17 SS1LE. Seems like it does nothing.
