Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Texas > Local Marketplace
Old 12-31-2015, 12:25 PM   #1
2012InfernoSS
2012InfernoSS's Avatar
Drives: 93GMC sierra stepside/ ctsv3
Fully built 2012 Camaro IOM price drop
Ive decided to sell my Camaro, I have put a lot of time into this car and when you see it.. it shows.
The car has almost 13k miles on it right now and only almost 3k miles on the new fully built motor, below is the list of modifications I have done yo the car
TMS ( Thompson Motor Sports ) LSX 418 c.i. 10.1 compression Rated For 1500hp
4.000'' crankshaft
Thompson motorsports 6.125" connection rods
Diamond Pistons
Performance file fit ring set
King racing narrowed rod &main bearings
GMPP cam Bearings
Arp main studs
Arp head bolts
Melling high pressure oil pump
Prc 260 6 bolt heads with ls9 head gaskets
Brian Tooley rocker Arm Turnion Upgrade
Brian Tooley Pushrods
C5 R timing chain
ls2 chain dampener
Custom Ground Turbo Cam 235*-244*-118 +4* .638” .622”
Stock ls3 intake with Nasty Nate Fuel rails
129lbs Fuel injectors
Lokar Oil dip stick
Mcload RXT clutch with remote bleeder
Ideal Garage modified clutch slave cylinder
MGW Full replacement shifter with 2013+ shift knob
Improved Racing Dynamics 180degree oil cooler block with added Mishimoto 19 row aluminum oil cooler
Fore Innovation Level 4 dual fuel system ( 2 Walbro 450's ) with -8an feed and -10 return fuel lines and reusable fuel filter
DeWitt's high performance aluminum direct fit radiator
RX color matched catch can
Pro Sport A/F and Boost gauge with pillar pod
Poly motor mounts
Texas speed 2 inch into 3inch long tube headers
Kooks full 3 inch exhaust header back no cats
Pedders supercar coil overs
Pedders steering rack bushings
Pedders radius rod bushings
Pfadt trailing arms
Pfadt Solid rear sub frame bushings
JP Superior Solutions rear sway bar
ZL1 Front 6 piston Brembo brakes ( front and rear calipers have been professionally powder coated )
Gforce engineering 1320 bolt in 9inch irs kit
Forgeline 3 piece GX3 20" Rims 275 front Nitto Invo's 315 rear Nitto Nt05's
Oem ZL1 hood with painted carbon fiber insert
Daytime driving lights have been replaced with projector sytle to match the headlights and added 5k hid's from Diode Dynamics
Color match bowties and tail light bezels
Sequential LED Rear Lamps with Rapid Fire and Afterburner
Also under the hood as been completely wire tucked and cleaned, I was planning on doing a custom top mount twin turbo setup, ecu and fuse box has all been safely relocated under the cowl by the cabin air filter area. The engine harness has also been modified, originally it would run from the back of the passenger side down to the front of the engine and cross over to the drivers side and run back down.. To clean it up I made the harness run from the back and both sides run down to the front to keep the loom form crossing the front of the engine bay to give it a nice clean appearance. When the original motor was removed the ac system stayed in the car so the factory freon did not escape the system and the ac is still as cold as it was when I bought the car
Car has been Tuned and everything went over by JMS after engine install and wire tucked
it was dyno tuned and made 505whp
The car has been a weekend or once a week to work car, I built the car to take it to the strip but never taken it. the car has been well taken care of, looks and smell brand new inside and out.. Always been in a garage with a car cover when not being driven, I wipe it down every time I drive it and never leave it setting dirty also never been purposely driven in the rain but I have been caught in the rain once or twice.
Not looking for trades and I am not hurting so it don't haft to be sold. Price is negotiable, No joyrides
If you have any question or want more pictures ( I have a ton ) feel free to PM or text me if you are serious about purchasing.
40k
2012InfernoSS is offline   Reply With Quote
Old 01-01-2016, 02:03 PM   #2
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
Damn dude, this is a seriously good deal for someone that wants to have a 1300 wheel Camaro. Just add a Turbo kit and have it tuned...
Sent from my iPhone
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 01-01-2016, 05:52 PM   #3
flyer08
Drives: 2010 2SS/RS
If only my engine bay looked that clean. Car looks awesome
flyer08 is offline   Reply With Quote
Old 01-01-2016, 10:18 PM   #4
synaptik
Drives: 2016 2lt RS
nice ride boss ... good luck with your sale
synaptik is offline   Reply With Quote
Old 01-02-2016, 12:53 AM   #5
2012InfernoSS
Thanks guys
Sent from my ONE A2005 using Tapatalk
Old 01-11-2016, 11:37 AM   #6
2012InfernoSS
Ttt
Old 01-25-2016, 03:22 PM   #7
2012InfernoSS
BUMP
Old 01-28-2016, 01:17 PM   #8
DFWZ28
DFWZ28's Avatar
Drives: 2010 SS
that is a beauty!!! good luck with your sale buddy.
DFWZ28 is offline   Reply With Quote
Old 01-28-2016, 10:53 PM   #9
Kgarner1624
Kgarner1624's Avatar
Drives: 13' BRM ZL1 A6
Still for sale?
Kgarner1624 is offline   Reply With Quote
Old 03-27-2016, 07:39 AM   #10
2012InfernoSS
Price drop
Old 04-23-2016, 12:41 PM   #11
2012InfernoSS
ttt
Old 04-28-2016, 12:15 PM   #12
My Caroline
My Caroline's Avatar
Drives: Black 2011 Camaro LS
Just curious, what wicker bill is that?
Nice car.
White Fender Hashes from Big Worm Graphix with Custom White Bowties
GM Factory Remote Start and Factory Key Fob
SS Fascia, Factory RS HIDs, Plasma P13W fog lights
Non-RS to RS and fog light harness by Gen5DIY
LED Interior, Trunk, and Licence Plate lights in white
ZL1 Spoiler with Gen5DIY harness
Factory NPP cat back
Blacked out tail light bezels
Factory 20 inch wheels wrapped in Nitto Motivos
Lowered 1.25inch on Eibach Pro springs
My Caroline is offline   Reply With Quote
Old 06-15-2016, 02:19 PM   #13
2012InfernoSS
To the Top
Old 07-17-2016, 09:44 AM   #14
2012InfernoSS
TTT,
Needs nothing but boost to make reliable 1000whp
