BeckyD @ James Martin Chevy
Old 09-05-2017, 08:12 AM   #29
lopezangel886
Drives: 2016 v6 camaro rs
Originally Posted by RobertAvitia View Post
That honestly looks lower then what they advertised and I might get em
Weird right? They seem to be a little lower now too than when that video was recorded so I can say the drop was perfect
lopezangel886 is offline   Reply With Quote
Old 09-05-2017, 09:31 AM   #30
rorymick
rorymick's Avatar
Drives: 2016 Camaro RS 1LT 2.0L Turbo
I can only assume the 4cyl will get a slightly less drop from these. Hmmmm ...
'16 1LT 2.0T RS - Catless DP, Intake, Tune/ Eibach springs FE3 shocks/ BMR front bar FE4 rear bar/ Xpel'd front end, CP Reload sealed/ Radenso Pro M.
rorymick is offline   Reply With Quote
Old 09-06-2017, 12:42 AM   #31
rorymick
rorymick's Avatar
I ordered Eibach springs today as well as a BMR adjustable front sway bar and the FE3 end links. Fingers crossed everything is here by Sep 13.
Old 09-07-2017, 08:19 PM   #32
lopezangel886
Post pics when installed I wanna see!!
Old 09-11-2017, 08:46 PM   #33
Mjollnir
Mjollnir's Avatar
Drives: 2017 1LS White
Update after install
The drop, 1" in the front and 1-1/4" in the rear.
The ride is much stiffer and in my opinion AFE got it right for street use. In that as a daily driver on bad streets it's tolerable.
Where these springs come to life is in the corners in comparison to stock. I have AFE swaybars front and rear set in the middle hole riding on
HTR Z III - Size: 285/30ZR20 square setup. It corners hard now and predictable at the limits of adhesion, but it's a strain to stay seated.
New seats now have taken priority over other upgrades.
If anyone is considering these tires, as they are the best bang for the buck (IMO), just remember water is like kryptonite to these tires.
Dislikes:
Currently going over speed bumps I hear clunking in the front and will be
talking to the installer about this and a follow up call to AFE.
The tire pics didn't post in the correct orientation where the end of the tape
measure is touching the ground and drawn up centered on the wheels.
1 Front tire
2 Reat tire
3 Body
Mjollnir is offline   Reply With Quote
Old 09-13-2017, 11:53 AM   #34
laborsmith
Drives: 1969 Corvair, 2018 Camaro T4 RS
Received the aFe lowering coils Monday, went to the service shop yesterday to set a date (expecting Thursday or Friday) and they took it right in, therefore did not get before measurements. Looks like a 1" drop for all four corners, maybe a little more for the rears.
Drove over the rough roads of southern Macomb County (Ten Mile between Mound and Dequindre, for example) as well as some speed bumps: no clunking noticed. The ride is firmer than OEM, but matches my idea of an excellent ride.
This is on a 2018 Camaro LT 2.0 which is not listed by aFe because they haven't accessed a 2018 yet for their own tests.
Laborsmith
laborsmith is offline   Reply With Quote
Old 09-24-2017, 06:52 PM   #35
RobertAvitia
BYND GARAGE
RobertAvitia's Avatar
Drives: 17' 1LT Turbo
Laborsmith
Any pictures??
RobertAvitia is offline   Reply With Quote
Old 09-25-2017, 08:40 AM   #36
laborsmith
No pictures for now but once I receive and get the 1LE Skorpion hood installed that is my plan.
The car has settled and it has a sport car feel. Again no problems with rough pavement or shopping center etc. speed strips.
Laborsmith
Old 09-25-2017, 09:06 AM   #37
Mjollnir
Mjollnir's Avatar
Originally Posted by cooper1965 View Post
Did you do a square wheel by any chance, or is that the standard offset with square tire size?
Looks great!
Square wheels for a 4 tire rotation. After seeing the full body pic again, the
tire offset is deceiving and appears to be tucked into the wheel well which it is
not.
Old 09-29-2017, 09:21 AM   #38
Mjollnir
Mjollnir's Avatar
If you lost a 1/2 inch of tire width, do you think a 2" taller OD tire would clear your setup? Thanks for any insight into clearance
I'm currently running 285-30-20 and according to Tirerack the dia. is 26.7.
Just to be clear are you asking whether a 28.7 dia tire will fit in my setup which
was lowered F 1" R 1.5"?
Old 09-30-2017, 03:43 PM   #39
Mjollnir
Mjollnir's Avatar
^ Yes, basically. Just wondering if their is an inch of clearance in those rear wheel wells if the wheel was centered.
All four wheels are 20 x 10 +23 and would have no problem in the rear.
The front however looks sketchy in that it would fit but I can't predict the
outcome driving on that size of tire.
