11-29-2022, 04:30 PM | #1 |
Drives: 2019 Camaro SS 1LE Join Date: Oct 2022
Camaro water damage?
Hey so I had my puppy pee in my passenger floor when I was taking her to the vet because of a broken leg, very tragic situation. But anyway I had to shampoo the floor like 7 times now trying to get that god forbidden smell out and I was wondering if the water from the shampooer will leave any type of water damage, I’ve had to soak the floor and now I’m worried if that would be a problem.
11-29-2022, 04:51 PM | #2 |
L8ap3x
I would recommend a professional detailer. They use an extractor that's far superior to what the average consumer has at home. I'm on a detailing forum and for example a decent one like Myree costs $1k starting. Something like this would be 15mins worth of easy work for them. For the long term smell, bacteria and biohazard now in that carpet, leave it to a professional. Our Camaros are worth that.
I'm sorry about your pup. I lost mine this summer and just today I was standing over his grave having a moment. It's gonna be hard this holiday season without him. Tbh, I could be coping better. Anyways. Enough sappy stuff. Good luck to you and your fur baby. Edit: get on FB and become a member of "detailing 101 by autogeek". Not only will you learn a lot, you'll likely get the same answer if not get a recommendation on someone in your area. "GLEN e" is also a detailing geek here on these forums. He's also a good resource.
"Manuals win hearts. Automatics win races."
2018 2SS 1LE HBM 6M |
11-29-2022, 07:28 PM | #3 |
Drives: 2016 Camaro SS Vert. Join Date: Apr 2017
I’d try positioning a fan in the direction of the floor and try drying it out just as a preventative measure against mold forming in the future.
11-29-2022, 07:58 PM | #4 |
Drives: Chevy camaro Join Date: Jan 2022
Use the a wet/dry vac to suck the water out of the carpet.
Glenn
2017 Camaro 2LT RS Convertible |
11-30-2022, 04:27 AM | #5 |
I would recommend taking the carpet out of the car to clean it. You can then also check to see if there is any water still on the floor board.
You need to remove the seats and a few other things but it is actually pretty easy to do. Also, an excellent time to do the seat reclining mod also. Hope your puppy is okay. Last edited by Spaceme1117; 11-30-2022 at 06:10 AM. |
11-30-2022, 05:54 AM | #6 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Hope you get your car cleaned up... but even FAR more important... How is your puppy doing. That's sad...
11-30-2022, 07:10 AM | #7 |
you need something that will break down the enzyms from the pee
regular carpet shampoo wont remove that https://www.autoality.com/store/pc/P...oz-61p8805.htm https://www.petsuppliesplus.com/cate...128&position=5 The skouts honor stuff works really well
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22 New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17 8/24. IT HAS ARRIVED at the dealer 8/25- It is in the Garage ACS ZL1 Sideskirts, 20% tint, CAI Intake |
11-30-2022, 09:23 AM | #8 | |
Drives: 2016 2SS Convertible Join Date: Dec 2019
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
11-30-2022, 12:02 PM | #9 |
Drives: 2023 ZL1 A10 Join Date: Nov 2021
I hope as all you pooch is doing well first and up most .
All the above are very good suggestions, and will work , some maybe a little overkill , but how much did your pooch pee, on the front passenger floor , I can suggest trying this first before you remove the seat and replace the padding, Walmart households dept has a cleaner specifically made for pet urine (can't remember the brand ) used it before and works to disinfect and neutralise the possible urine smell . Pull the door sill plate off , lift the carpet an pad , shampoo both use neutraliser , use towels to pat dry prop up carpet and pad with paint stick or 2 , or like object and run a space heater ( common in most homes or a hair dryer , monitor for safety reasons . I bet this will totally eliminate the problem. We had the same issue a few years back in my wife's new Tahoe our pooch had an accidental pee from a UTI couldn't control herself. A suggestion. Happy Motoring. Again hope your pooch is recovering .
2023 ZL1 A10 Shadow Gray Metallic
11-30-2022, 12:22 PM | #10 | |
Faster!!!
Drives: 2020 Camaro 1SS 1LE Join Date: Mar 2020
First, hope the pup is ok. This is the best suggestion I have seen, was about to post something very similar. |
11-30-2022, 12:34 PM | #11 | |
Electrical Engineer
Drives: 2023 1SS A10 Black Join Date: Apr 2022
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
11-30-2022, 03:03 PM | #12 |
Drives: 22 LT1 Join Date: Oct 2022
Rocco & Roxie Pet Stain & Odor Remover is my "go to" enzyme based cleaner.
2 dogs - one just turned 1, the other nearing 2, tons of accidents on my carpets and you'd never know. You'll still probably want to get the car to a detailer or replace the carpet and what's underneath at some point, but, dogs are like kids - keeping things nice can be tough, and expensive. |
12-11-2022, 10:21 PM | #13 | |
How do I go about removing the carpet exactly? |
12-12-2022, 11:03 AM | #14 |
I just joined.
2020 Camaro 2SS - Riverside Blue, NPP, Magnetic Ride, Sunroof
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
camaro, damage |
