11-20-2022, 04:43 PM | #1 |
Drives: 2013 Join Date: Mar 2017
Running 2 different brands of tires
I have 2 new goodyear run flats. I was wondering if I could use pirelli runflats all 4 the same size. Thx
11-20-2022, 05:05 PM | #2 |
I don't see why not as long as they are rated the same. Just keep the same brand on the fronts and back and you shouldn't have a problem.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | ZL1addons Deluxe Rock Guards and Stealth Lift Pads | Escort MAXcam360c | Footwell Lighting |
11-21-2022, 08:06 AM | #3 |
I run 2 different brand tires on my car, both winter and summer
For Summer Eagle SC3's on the back and Advan V105's on the front. For Winter Vredestein on the back and regular all season on the front.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
11-21-2022, 09:41 AM | #4 |
Not an issue but it would be best to keep the tread design close for similar handling front and rear.
11-21-2022, 08:19 PM | #5 |
Because why? There isnt even equal traction front and rear stock. Cars are intended to understeer from the factory, especially at lower performance levels. But staggered setups and different weight distributions make this idea of having to run the same tires ridiculous. There are some things like making sure you aren’t going with radically different compound ratings and obvious dangerous oversteer setups, but there’s also no good reason to match tires front to rear on a RWD or FWD car…in fact id argue opposite of this is closer to optimal…
11-22-2022, 09:40 AM | #6 |
Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
"Pumps 1 and 3, hit 'em."
"You got one regular and one premium." "She goes both ways."
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
11-22-2022, 06:06 PM | #7 |
Drives: 2020 Camaro SS 1LE Join Date: Apr 2022
I have a pair of michelin cup 2s up front and pirelli corsas in rear. Works fine and I did it for cost. Got good deals on pairs of tires.
Thread Tools | |
