11-09-2022, 11:05 PM | #1 |
2014 2SS/RS Dyno numbers
Anyone else have numbers like these from their SS w/automatic? Am I reading the numbers wrong as it appears I'm not getting advertised 400hp?
[ATTACH] |
11-09-2022, 11:19 PM | #2 |
400 is crank HP. Wheel Hp will always be less at the wheels because of drive train losses.
ABM #2399 2SS/RS:SOLD
11-09-2022, 11:26 PM | #3 |
Drives: 2010 ABM Camaro SS M6 Join Date: Jul 2020
The percentage loss numbers on this forum vary. Mostly I've see 14-15% for M6 and 17-19% for A6. So, those are probably at least in the ballpark.
11-10-2022, 04:54 AM | #4 |
Thanks for the responses. I had the car in SS mode and was using the paddle shifters for the tests. These were measured based on 4th gear at max RPM of 6K. If I account for loss, it comes out to 396hp. I was hoping for slightly higher numbers since I swapped out the exhaust and cold intake.
11-10-2022, 05:36 AM | #5 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
All dynos vary as well as different ambient conditions. 315-330rwhp is the average for a L99. You are on the low side but could make 327whp on a different dyno on a different day.
11-10-2022, 06:17 AM | #6 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Also, I'm assuming that wasn't a Dyno. Looks like more likely software that is predicting hp and tq. Those aren't the most accurate, but give you a ball park number, and you're in the ballpark.
11-10-2022, 07:08 AM | #7 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
A Dyno, whether an actual dyno or a virtual one, is just a tool. The real value to it is measuring after versus before a change. Did you do any baseline runs before installing new parts?
11-10-2022, 07:32 AM | #8 |
It was a real dyno. The dyno was called something like Mustang. They even let me run my car on it instead of them controlling the RPMs and gears.
Unfortunately, I didn't create a baseline before the mods. That was stupid of me which I realized after the fact. |
11-10-2022, 07:33 AM | #9 |
Mustang always read low, especially compared to a DynoJet.
11-10-2022, 08:13 AM | #10 |
Catback exhaust and cold air rarely see much of a power increase.
11-10-2022, 08:45 AM | #11 |
Good fo know about the mustang dyno.
11-10-2022, 09:12 AM | #12 |
11-10-2022, 09:37 AM | #13 |
Fast Cars and Old Guitars
All I know is that it seems so many cars now have more HP (and beat me to the next light) driving this 7 year old 'muscle car.' Whether it's an Audi, Infinity, Mustang, Challenger, Charger, etc. it's enough to drive a man to mod his car and start down that money pit!
11-10-2022, 09:44 AM | #14 | |
Drives: 2015 zl1 m6 Join Date: Jan 2020
Do it !!
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.7 @133.9 |
