11-03-2022, 02:00 PM | #1 |
Drives: Camaro SS Join Date: Nov 2022
1LE Spoiler help
Hello new to the forum here. I removed my factory trunk/spoiler to install a carbon fiber trunk/duckbill only to be left over with this epoxy. Any ideas on how to remove it?
https://ibb.co/wwkJhfp https://ibb.co/j6CypKB Last edited by Gus27; 11-03-2022 at 02:10 PM. |
11-03-2022, 03:24 PM | #2 |
Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
Welcome to the forum.
You are likely going to need heat (blow dryer or heat gun) and some adhesive remover, like Goo Gone or 3M to get it off. I'd start with heat and see if you can peel it off. If you use a heat gun be careful not to get it too hot or you could damage the paint.
2023 Summit White ZL1 M6 (delivered 10/15/23)
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
11-03-2022, 06:55 PM | #3 |
i didnt think it would work but you need to get one of those eraser wheels.
I had to redo my winglets and had to use one to remove that adhesive
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22 New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17 8/24. IT HAS ARRIVED at the dealer 8/25- It is in the Garage ACS ZL1 Sideskirts, 20% tint, CAI Intake |
11-03-2022, 07:37 PM | #4 |
I’ll give it a try, but this seems to be like almost like a resin, it’s not sticky to the touch it’s very hard and has no play when I try prying on it. I took it two a couple body shops and they said they need to grind it down and re spray the whole rear quarter panels if I wanted it done right only problem is the whole car has paint protection film and it’s brand new too. I rather not go that route.
11-03-2022, 07:42 PM | #5 | |
those body shops are either idiots or just want to get you to pay some money. use the eraser wheel and just do little at a time let it cool and keep going. I didnt do any damage to my paint
11-03-2022, 07:45 PM | #6 | |
11-03-2022, 08:07 PM | #7 |
i bought this one. was basically one of the first ones to pop up. they are all the same
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
11-04-2022, 07:07 AM | #8 |
I had one of my winglets FALL OFF going down the highway and then removed the other side and I never encountered what you're showing there but the winglets are dealer installed and someone could have mega glued yours as opposed to not doing a great job with mine. If they put some kind of expoxy cement you're body shop is probably the only option.
11-04-2022, 08:51 AM | #9 | |
It will come off with the eraser wheel. Took me about 20mins per side going slow and making sure nothing bad happened. Body shop isnt needed at all.
11-08-2022, 12:55 PM | #10 |
Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
That looks like windshield urethane. It's a bitch to remove.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
11-09-2022, 03:43 PM | #11 |
11-09-2022, 06:06 PM | #12 |
just go slow and dont heat up the paint to much. when you get it down to close to the paint. do like 30sec and then let it cool a bit and do it again till its all gone
11-10-2022, 07:26 AM | #13 |
Drives: '23 1LE, '18 Canyon, '87 325i Join Date: Jul 2022
You may be able to use some hot water to help soften the glue.
If it's an epoxy, it will still be hard, so the eraser wheel is a good option. Just take your time and be patient, it will be worth it not to scar the paint. |
